warnings
updates #2577.
For the usiii BSP variant without this option sample executables
sizes were as follows:
180608 2752 2113472 2296832 230c00 ticker.exe
114112 1760 2105312 2221184 21e480 minimum.exe
1041392 3168 2126160 3170720 3061a0 cxx_iostream.exe
712224 8912 2129200 2850336 2b7e20 fileio.exe
595248 21568 2147872 2764688 2a2f90 pppd.exe
291488 3912 2117440 2412840 24d128 capture.exe
200496 2888 2113616 2317000 235ac8 nsecs.exe
279344 3392 2114112 2396848 2492b0 paranoia.exe
324656 2768 2115328 2442752 254600 cdtest.exe
178624 2752 2113440 2294816 230420 base_sp.exe
179152 2752 2117216 2299120 2314f0 unlimited.exe
190944 2688 2113424 2307056 2333f0 hello.exe
381296 10752 2126400 2518448 266db0 loopback.exe
For the usiii BSP variant with this option sample executables sizes
were as follows:
173312 2632 2113184 2289128 22ede8 ticker.exe
102432 328 2100928 2203688 21a028 minimum.exe
626544 3032 2120400 2749976 29f618 cxx_iostream.exe
657584 8792 2128640 2795016 2aa608 fileio.exe
555616 21264 2146816 2723696 298f70 pppd.exe
280016 3760 2117152 2400928 24a2a0 capture.exe
193792 2768 2113312 2309872 233ef0 nsecs.exe
238528 3264 2113808 2355600 23f190 paranoia.exe
277568 2664 2115040 2395272 248c88 cdtest.exe
170592 2624 2113152 2286368 22e320 base_sp.exe
169120 2616 2112816 2284552 22dc08 unlimited.exe
180528 2536 2109040 2292104 22f988 hello.exe
354992 10528 2126016 2491536 260490 loopback.exe
updates #2577.
For the niagara BSP variant without this option sample executables
143616 2704 2113472 2259792 227b50 ticker.exe
71872 1720 2105312 2178904 213f58 minimum.exe
983600 3128 2126160 3112888 2f7fb8 cxx_iostream.exe
648448 8864 2129200 2786512 2a84d0 fileio.exe
548976 21520 2147872 2718368 297aa0 pppd.exe
253344 3872 2117440 2374656 243c00 capture.exe
161520 2840 2113616 2277976 22c258 nsecs.exe
215568 3344 2114112 2333024 239960 paranoia.exe
261744 2728 2115328 2379800 245018 cdtest.exe
139648 2704 2113440 2255792 226bb0 base_sp.exe
142416 2712 2117216 2262344 228548 unlimited.exe
150464 2648 2113424 2266536 2295a8 hello.exe
343504 10704 2126400 2480608 25d9e0 loopback.exe
For the niagara BSP variant with this option sample executables
133408 2624 2113184 2249216 225200 ticker.exe
57152 320 2100928 2158400 20ef40 minimum.exe
590160 3024 2120400 2713584 2967f0 cxx_iostream.exe
623568 8784 2128640 2760992 2a2120 fileio.exe
503616 21256 2146816 2671688 28c448 pppd.exe
239152 3752 2117152 2360056 2402f8 capture.exe
152128 2760 2113312 2268200 229c28 nsecs.exe
203808 3256 2113808 2320872 2369e8 paranoia.exe
244128 2656 2115040 2361824 2409e0 cdtest.exe
128672 2616 2113152 2244440 223f58 base_sp.exe
129408 2608 2112816 2244832 2240e0 unlimited.exe
137040 2528 2109040 2248608 224fa0 hello.exe
314256 10520 2126016 2450792 256568 loopback.exe
Update #2408.
This avoids potential dead code in _Thread_Handler(). It gets rid of
the dangerous function pointer casts.
Update #2514.
Update #2408.
Update #2408.
do
echo $b
# echo $g
-i $b
done
Update #2271.
The sparc64 port had some incorrect copyright notices affixed to
source code files.
sparc64_install_isr_entries function is no longer used. Removing it also
allows to use the default bsppredriverhook for usiii and bspstart for niagara.
warning and clean up
not updated.
The TLS section symbols had wrong values in case of an empty TLS data
section and a nonempty TLS BSS section.
Terminates the execution of niagara BSP when running in gem5.
The work areas (RTEMS work space and C program heap) will be initialized
now in a separate step and are no longer part of
rtems_initialize_data_structures(). Initialization is performed with
tables of Heap_Area entries. This allows usage of scattered memory
areas present on various small scale micro-controllers.
The sbrk() support API changes also. The bsp_sbrk_init() must now deal
with a minimum size for the first memory chunk to take the configured
work space size into account.
Conflicts:
These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
XXX
