This avoids potential dead code in _Thread_Handler(). It gets rid of
the dangerous function pointer casts.
Update #2514.
Update #2408.
Update #2408.
do
echo $b
# echo $g
-i $b
done
Update #2271.
The sparc64 port had some incorrect copyright notices affixed to
source code files.
sparc64_install_isr_entries function is no longer used. Removing it also
allows to use the default bsppredriverhook for usiii and bspstart for niagara.
warning and clean up
not updated.
The TLS section symbols had wrong values in case of an empty TLS data
section and a nonempty TLS BSS section.
Terminates the execution of niagara BSP when running in gem5.
The work areas (RTEMS work space and C program heap) will be initialized
now in a separate step and are no longer part of
rtems_initialize_data_structures(). Initialization is performed with
tables of Heap_Area entries. This allows usage of scattered memory
areas present on various small scale micro-controllers.
The sbrk() support API changes also. The bsp_sbrk_init() must now deal
with a minimum size for the first memory chunk to take the configured
work space size into account.
Conflicts:
These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
XXX
for details.
PR bsps/1989
* shared/start/start.S, shared/startup/linkcmds: Boot stack and heap
space improvements.
PR bsps/1988
* shared/start/start.S: Add _init and _fini to .init and .fini sections
PR bsps/1988
* shared/startup/linkcmds: Relocate .init and .fini sections closer to
.text.
* shared/console/conscfg.c: Whitespace and style fixes.
* shared/console/conscfg.c: Give console port a name.
PR 1917/bsps
* shared/console/conscfg.c: Modifications to add dynamic tables for
libchip serial drivers.
PR 1917/bsps
* Makefile.am: Modifications to add dynamic tables for libchip serial
drivers.
PR 1920/bsp
* shared/helenos/kernel/sparc64/src/sun4u/takemmu.S,
shared/start/start.S, shared/startup/bspgetworkarea.c,
shared/startup/linkcmds: Fix BSP memory use to support more than 4 MB
of RAM.
