Update #4267.
controller support.
Update #3269.
Updates #3425.
Updates #3425.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
system. Since all content of
makes no sense to keep it.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #2408.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3387.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
upgrade to that version.
Close #3387.
Update #3285.
Update #3285.
Update #3285.
The boot/stack.h header contains duplicated macros that are
redundant to arch/stack.h. Delete the boot/stack.h and replace
its one use by the arch/stack.h.
Closes #3341.
Update #3285.
* bsps/shared/cache
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
EXTRA_DIST += foobar
in fragments.
Update #3254.
Updates #3520.
Updates #3520.
Patch was not intended to be pushed yet.
Updates #3520.
Done:
arm
bfin
epiphany
i386
lm32
m32c
mips
moxie
nios2
or1k
powerpc
riscv
sh
sparc
sparc64
v850
To do:
m68k
Differences noted:
+ endfile was sometimes before startfile
+ endfile sometimes was hard-coded and did not have -qrtems version
+ Should -e XXX (e.g. entry point) be in linkcmds?
+ Should -u XXX (e.g. undefined symbols) be in linkcmds?
+ Typos: Odd spacing, "old_endfiles" typo, and *(old_endfiles) (not %)
+ nios2: Referenced crtnn.o not crtn.o (error)
Need to revisit:
+ m32c, moxie, sparc64 includes !nostdlib which is not used elsewhere
+ sh has -EL/-EB mapping. Why needed?
+ sparc64 didn't include crti.o/crtn.o but it is part of toolset
+ v850 uses something like this for link and end_file:
"%{qrtems: %(old_link)}"
This means that these are unnecessary. Try this on all.
+ mips uses old_link all the time also.
+ arm/tms750 adds -EB.
+ powerpc: Why do we have rtems_crt* and not use something from GCC?
Updates #3520.
Updates #3250.
header file.
Update #3254.
Update #3254.
maintain.
Update #3254.
BSP_PRESS_KEY_FOR_RESET=0
BSP_RESET_BOARD_AT_EXIT=1
BSP_PRINT_EXCEPTION_CONTEXT=1
Update #3239.
