The work areas (RTEMS work space and C program heap) will be initialized
now in a separate step and are no longer part of
rtems_initialize_data_structures(). Initialization is performed with
tables of Heap_Area entries. This allows usage of scattered memory
areas present on various small scale micro-controllers.
The sbrk() support API changes also. The bsp_sbrk_init() must now deal
with a minimum size for the first memory chunk to take the configured
work space size into account.
These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
PR bsps/1989
* shared/start/start.S, shared/startup/linkcmds: Boot stack and heap
space improvements.
PR bsps/1988
* shared/start/start.S: Add _init and _fini to .init and .fini sections
PR bsps/1988
* shared/startup/linkcmds: Relocate .init and .fini sections closer to
.text.
* shared/console/conscfg.c: Whitespace and style fixes.
* shared/console/conscfg.c: Give console port a name.
PR 1917/bsps
* shared/console/conscfg.c: Modifications to add dynamic tables for
libchip serial drivers.
PR 1920/bsp
* shared/helenos/kernel/sparc64/src/sun4u/takemmu.S,
shared/start/start.S, shared/startup/bspgetworkarea.c,
shared/startup/linkcmds: Fix BSP memory use to support more than 4 MB
of RAM.
PR 1919/bsp
* shared/startup/bsppredriverhook.c: New file.
PR 1770/bsps
* shared/console/conscfg.c: Rely on default device file registration.
PR 1691/bsps
* shared/clock/ckinit.c: The sparc64/shared/clock driver has
a bug that causes nested timer interrupts to not be serviced,
which leads to non-preemptive behavior especially when dispatching
work from the timer ISR.
PR 1691/bsps
* shared/include/traptable.h, shared/start/trap_table.S,
shared/startup/linkcmds: Create a dummy trap table
that jumps to the firmware trap table for default trap handlers.
PR 1691/bsps
* shared/include/traptable.h: Double the size of TABLE_SIZE to copy
code branched to from the trap table.
* shared/startup/linkcmds: Add .gcc_except_table*.
PR 1634/bsps
* shared/console/conscfg.c: Add BSP_poll_char.
* ChangeLog, Makefile.am, acinclude.m4, configure.ac, shared/asm/asm.S,
shared/clock/ckinit.c, shared/console/conscfg.c,
shared/helenos/LICENSE, shared/helenos/README,
shared/helenos/boot/genarch/balloc.c,
shared/helenos/boot/genarch/ofw.c,
shared/helenos/boot/genarch/ofw_tree.c,
shared/helenos/boot/generic/string.c,
shared/helenos/boot/include/align.h,
shared/helenos/boot/include/balloc.h,
shared/helenos/boot/include/gentypes.h,
shared/helenos/boot/include/main.h,
shared/helenos/boot/include/ofw.h,
shared/helenos/boot/include/ofw_tree.h,
shared/helenos/boot/include/ofwarch.h,
shared/helenos/boot/include/register.h,
shared/helenos/boot/include/stack.h,
shared/helenos/boot/include/types.h,
shared/helenos/boot/sparc64/loader/main.c,
shared/helenos/boot/sparc64/loader/ofwarch.c,
shared/helenos/boot/sparc64/loader/ofwasm.S,
shared/helenos/kernel/genarch/include/ofw/ofw_tree.h,
shared/helenos/kernel/generic/include/align.h,
shared/helenos/kernel/sparc64/include/arch.h,
shared/helenos/kernel/sparc64/include/boot.h,
shared/helenos/kernel/sparc64/include/regdef.h,
shared/helenos/kernel/sparc64/include/stack.h,
shared/helenos/kernel/sparc64/include/mm/cache_spec.h,
shared/helenos/kernel/sparc64/include/mm/frame.h,
shared/helenos/kernel/sparc64/include/mm/mmu.h,
shared/helenos/kernel/sparc64/include/mm/page.h,
shared/helenos/kernel/sparc64/include/mm/tlb.h,
shared/helenos/kernel/sparc64/include/mm/tte.h,
shared/helenos/kernel/sparc64/include/mm/sun4u/frame.h,
shared/helenos/kernel/sparc64/include/mm/sun4u/mmu.h,
shared/helenos/kernel/sparc64/include/mm/sun4u/page.h,
shared/helenos/kernel/sparc64/include/mm/sun4u/tlb.h,
shared/helenos/kernel/sparc64/include/mm/sun4u/tte.h,
shared/helenos/kernel/sparc64/include/sun4u/arch.h,
shared/helenos/kernel/sparc64/src/cache.S,
shared/include/asm.h, shared/include/traptable.h,
shared/start/start.S, shared/start/trap_table.S,
shared/startup/bspgetworkarea.c, shared/startup/bspstart.c,
shared/startup/linkcmds, shared/startup/setvec.c: New files.
