path: root/c/src/lib/libbsp/sparc64/shared/clock (follow)
* 2010-11-16 Gedare Bloom <giddyup44@yahoo.com>Joel Sherrill2010-11-161-2/+6
| | | | | | | | PR 1691/bsps * shared/clock/ckinit.c: The sparc64/shared/clock driver has a bug that causes nested timer interrupts to not be serviced, which leads to non-preemptive behavior especially when dispatching work from the timer ISR.
* 2010-06-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-06-171-0/+118
* ChangeLog, Makefile.am, acinclude.m4, configure.ac, shared/asm/asm.S, shared/clock/ckinit.c, shared/console/conscfg.c, shared/helenos/LICENSE, shared/helenos/README, shared/helenos/boot/genarch/balloc.c, shared/helenos/boot/genarch/ofw.c, shared/helenos/boot/genarch/ofw_tree.c, shared/helenos/boot/generic/string.c, shared/helenos/boot/include/align.h, shared/helenos/boot/include/balloc.h, shared/helenos/boot/include/gentypes.h, shared/helenos/boot/include/main.h, shared/helenos/boot/include/ofw.h, shared/helenos/boot/include/ofw_tree.h, shared/helenos/boot/include/ofwarch.h, shared/helenos/boot/include/register.h, shared/helenos/boot/include/stack.h, shared/helenos/boot/include/types.h, shared/helenos/boot/sparc64/loader/main.c, shared/helenos/boot/sparc64/loader/ofwarch.c, shared/helenos/boot/sparc64/loader/ofwasm.S, shared/helenos/kernel/genarch/include/ofw/ofw_tree.h, shared/helenos/kernel/generic/include/align.h, shared/helenos/kernel/sparc64/include/arch.h, shared/helenos/kernel/sparc64/include/boot.h, shared/helenos/kernel/sparc64/include/regdef.h, shared/helenos/kernel/sparc64/include/stack.h, shared/helenos/kernel/sparc64/include/mm/cache_spec.h, shared/helenos/kernel/sparc64/include/mm/frame.h, shared/helenos/kernel/sparc64/include/mm/mmu.h, shared/helenos/kernel/sparc64/include/mm/page.h, shared/helenos/kernel/sparc64/include/mm/tlb.h, shared/helenos/kernel/sparc64/include/mm/tte.h, shared/helenos/kernel/sparc64/include/mm/sun4u/frame.h, shared/helenos/kernel/sparc64/include/mm/sun4u/mmu.h, shared/helenos/kernel/sparc64/include/mm/sun4u/page.h, shared/helenos/kernel/sparc64/include/mm/sun4u/tlb.h, shared/helenos/kernel/sparc64/include/mm/sun4u/tte.h, shared/helenos/kernel/sparc64/include/sun4u/arch.h, shared/helenos/kernel/sparc64/src/cache.S, shared/helenos/kernel/sparc64/src/sun4u/takemmu.S, shared/include/asm.h, shared/include/traptable.h, shared/start/start.S, shared/start/trap_table.S, shared/startup/bspgetworkarea.c, shared/startup/bspstart.c, shared/startup/linkcmds, shared/startup/setvec.c: New files.
