do
echo $b
# echo $g
-i $b
done
The sparc64 port had some incorrect copyright notices affixed to
source code files.
sparc64_install_isr_entries function is no longer used. Removing it also
allows to use the default bsppredriverhook for usiii and bspstart for niagara.
Terminates the execution of niagara BSP when running in gem5.
The work areas (RTEMS work space and C program heap) will be initialized
now in a separate step and are no longer part of
rtems_initialize_data_structures(). Initialization is performed with
tables of Heap_Area entries. This allows usage of scattered memory
areas present on various small scale micro-controllers.
The sbrk() support API changes also. The bsp_sbrk_init() must now deal
with a minimum size for the first memory chunk to take the configured
work space size into account.
Conflicts:
for details.
PR 1917/bsps
* Makefile.am: Modifications to add dynamic tables for libchip serial
drivers.
* Makefile.am: Don't reference non-existing files.
* make/custom/niagara.cfg (CFLAGS_OPTIMIZE_V):
Replace -gstabs with -g.
PR 1769/bsps
* make/custom/niagara.cfg (CFLAGS_OPTIMIZE_V): Add -O2
* include/bsp.h:
PR 1591/bsps
* preinstall.am: Regenerate.
* .cvsignore, include/.cvsignore: New files.
* ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
preinstall.am, include/bsp.h, include/tm27.h,
make/custom/niagara.cfg, start/bspinit.S: New files.
