The work areas (RTEMS work space and C program heap) will be initialized
now in a separate step and are no longer part of
rtems_initialize_data_structures(). Initialization is performed with
tables of Heap_Area entries. This allows usage of scattered memory
areas present on various small scale micro-controllers.
The sbrk() support API changes also. The bsp_sbrk_init() must now deal
with a minimum size for the first memory chunk to take the configured
work space size into account.
Conflicts:
for details.
PR 1917/bsps
* Makefile.am: Modifications to add dynamic tables for libchip serial
drivers.
* Makefile.am: Don't reference non-existing files.
* make/custom/niagara.cfg (CFLAGS_OPTIMIZE_V):
Replace -gstabs with -g.
PR 1769/bsps
* make/custom/niagara.cfg (CFLAGS_OPTIMIZE_V): Add -O2
* include/bsp.h:
PR 1591/bsps
* preinstall.am: Regenerate.
* .cvsignore, include/.cvsignore: New files.
* ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
preinstall.am, include/bsp.h, include/tm27.h,
make/custom/niagara.cfg, start/bspinit.S: New files.
