The sparc64 port had some incorrect copyright notices affixed to
source code files.
Conflicts:
* include/bsp.h:
* .cvsignore, include/.cvsignore: New files.
* ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
preinstall.am, include/bsp.h, include/tm27.h,
make/custom/niagara.cfg, start/bspinit.S: New files.
