* | 2011-12-12 Gedare Bloom <gedare@rtems.org> | Gedare Bloom | 2011-12-12 | 1 | -0/+6 |
| | | | | | | PR bsps/1989 * shared/start/start.S, shared/startup/linkcmds: Boot stack and heap space improvements. | ||||
* | 2011-12-12 Gedare Bloom <gedare@rtems.org> | Gedare Bloom | 2011-12-12 | 1 | -0/+5 |
| | | | | | PR bsps/1988 * shared/start/start.S: Add _init and _fini to .init and .fini sections | ||||
| | | | | | | PR bsps/1988 * shared/startup/linkcmds: Relocate .init and .fini sections closer to .text. | ||||
* | 2011-11-06 Gedare Bloom <gedare@rtems.org> | Gedare Bloom | 2011-11-06 | 1 | -0/+4 |
| | | | | * shared/console/conscfg.c: Whitespace and style fixes. | ||||
| | | | | * shared/console/conscfg.c: Give console port a name. | ||||
* | 2011-10-18 Jennifer Averett <Jennifer.Averett@OARcorp.com> | Jennifer Averett | 2011-10-18 | 1 | -0/+6 |
| | | | | | | PR 1917/bsps * shared/console/conscfg.c: Modifications to add dynamic tables for libchip serial drivers. | ||||
* | 2011-10-06 Gedare Bloom <giddyup44@yahoo.com> | Joel Sherrill | 2011-10-06 | 1 | -0/+8 |
| | | | | | | | | PR 1920/bsp * shared/helenos/kernel/sparc64/src/sun4u/takemmu.S, shared/start/start.S, shared/startup/bspgetworkarea.c, shared/startup/linkcmds: Fix BSP memory use to support more than 4 MB of RAM. | ||||
* | 2011-10-06 Gedare Bloom <giddyup44@yahoo.com> | Joel Sherrill | 2011-10-06 | 1 | -0/+5 |
| | | | | | PR 1919/bsp * shared/startup/bsppredriverhook.c: New file. | ||||
* | 2011-06-20 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-06-20 | 1 | -0/+4 |
| | | | | * Makefile.am: Remove superfluous EXTRA_DIST. | ||||
* | 2011-03-21 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-03-21 | 1 | -0/+5 |
| | | | | | PR 1770/bsps * shared/console/conscfg.c: Rely on default device file registration. | ||||
* | 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-02 | 1 | -0/+4 |
| | | | | * configure.ac: Require autoconf-2.68, automake-1.11.1. | ||||
* | 2010-11-16 Gedare Bloom <giddyup44@yahoo.com> | Joel Sherrill | 2010-11-16 | 1 | -0/+8 |
| | | | | | | | | PR 1691/bsps * shared/clock/ckinit.c: The sparc64/shared/clock driver has a bug that causes nested timer interrupts to not be serviced, which leads to non-preemptive behavior especially when dispatching work from the timer ISR. | ||||
* | 2010-11-15 Gedare Bloom <giddyup44@yahoo.com> | Joel Sherrill | 2010-11-16 | 1 | -0/+7 |
| | | | | | | | PR 1691/bsps * shared/include/traptable.h, shared/start/trap_table.S, shared/startup/linkcmds: Create a dummy trap table that jumps to the firmware trap table for default trap handlers. | ||||
* | 2010-08-26 Gedare Bloom <giddyup44@yahoo.com> | Joel Sherrill | 2010-08-26 | 1 | -0/+6 |
| | | | | | | PR 1691/bsps * shared/include/traptable.h: Double the size of TABLE_SIZE to copy code branched to from the trap table. | ||||
* | 2010-08-03 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-08-03 | 1 | -0/+4 |
| | | | | * shared/startup/linkcmds: Add .gcc_except_table*. | ||||
* | 2010-07-27 Gedare Bloom <giddyup44@yahoo.com> | Joel Sherrill | 2010-07-27 | 1 | -0/+5 |
| | | | | | PR 1634/bsps * shared/console/conscfg.c: Add BSP_poll_char. | ||||
* | 2010-06-17 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-06-17 | 1 | -0/+4 |
| | | | | * .cvsignore: New file. | ||||
* | 2010-06-17 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-06-17 | 1 | -0/+90 |
* ChangeLog, Makefile.am, acinclude.m4, configure.ac, shared/asm/asm.S, shared/clock/ckinit.c, shared/console/conscfg.c, shared/helenos/LICENSE, shared/helenos/README, shared/helenos/boot/genarch/balloc.c, shared/helenos/boot/genarch/ofw.c, shared/helenos/boot/genarch/ofw_tree.c, shared/helenos/boot/generic/string.c, shared/helenos/boot/include/align.h, shared/helenos/boot/include/balloc.h, shared/helenos/boot/include/gentypes.h, shared/helenos/boot/include/main.h, shared/helenos/boot/include/ofw.h, shared/helenos/boot/include/ofw_tree.h, shared/helenos/boot/include/ofwarch.h, shared/helenos/boot/include/register.h, shared/helenos/boot/include/stack.h, shared/helenos/boot/include/types.h, shared/helenos/boot/sparc64/loader/main.c, shared/helenos/boot/sparc64/loader/ofwarch.c, shared/helenos/boot/sparc64/loader/ofwasm.S, shared/helenos/kernel/genarch/include/ofw/ofw_tree.h, shared/helenos/kernel/generic/include/align.h, shared/helenos/kernel/sparc64/include/arch.h, shared/helenos/kernel/sparc64/include/boot.h, shared/helenos/kernel/sparc64/include/regdef.h, shared/helenos/kernel/sparc64/include/stack.h, shared/helenos/kernel/sparc64/include/mm/cache_spec.h, shared/helenos/kernel/sparc64/include/mm/frame.h, shared/helenos/kernel/sparc64/include/mm/mmu.h, shared/helenos/kernel/sparc64/include/mm/page.h, shared/helenos/kernel/sparc64/include/mm/tlb.h, shared/helenos/kernel/sparc64/include/mm/tte.h, shared/helenos/kernel/sparc64/include/mm/sun4u/frame.h, shared/helenos/kernel/sparc64/include/mm/sun4u/mmu.h, shared/helenos/kernel/sparc64/include/mm/sun4u/page.h, shared/helenos/kernel/sparc64/include/mm/sun4u/tlb.h, shared/helenos/kernel/sparc64/include/mm/sun4u/tte.h, shared/helenos/kernel/sparc64/include/sun4u/arch.h, shared/helenos/kernel/sparc64/src/cache.S, shared/helenos/kernel/sparc64/src/sun4u/takemmu.S, shared/include/asm.h, shared/include/traptable.h, shared/start/start.S, shared/start/trap_table.S, shared/startup/bspgetworkarea.c, shared/startup/bspstart.c, shared/startup/linkcmds, shared/startup/setvec.c: New files. |
