Some register layout definitions for LEON3 reside in ambapp.h which
does not really has anything to do with device registers. The
register structures has been incorrectly named LEON3_*, the cores
are not only used on LEON3 but on LEON4 and perhaps on LEON5 when
that day comes. Some structures has been renamed according to the
GRLIB core name instead, which CPU that actually use it is not
relevant. Drivers has been updated with the new names.
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
The drivers are updated to use the new AMBA layer, however the
backwards-compatibility interface (ambapp_old) is used.
* shared/1553/b1553brm.c, shared/can/grcan.c, shared/can/occan.c,
shared/spw/grspw.c, shared/uart/apbuart.c:
* shared/1553/b1553brm.c, shared/can/grcan.c, shared/can/grcan_rasta.c,
shared/can/occan.c, shared/spw/grspw.c, shared/spw/grspw_pci.c,
shared/uart/apbuart.c: Remove warnings.
* shared/uart/apbuart.c: Fix some warnings.
New drivers: PCI, b1553BRM, SpaceWire(GRSPW), CAN (GRCAN,OC_CAN),
Raw UART.
* shared/1553/b1553brm.c, shared/1553/b1553brm_pci.c,
shared/1553/b1553brm_rasta.c, shared/can/grcan.c,
shared/can/grcan_rasta.c, shared/can/occan.c, shared/can/occan_pci.c,
shared/spw/grspw.c, shared/spw/grspw_pci.c, shared/spw/grspw_rasta.c,
shared/uart/apbuart.c, shared/uart/apbuart_pci.c,
shared/uart/apbuart_rasta.c: New files missed in previous commit.
