The window underflow trap handler used %i5 which destroyed the %o5 of
the calling context. Bug introduced by
0d3b5d47429effb350448d9e9123a67db722109f.
Go back to the pre 0d3b5d47429effb350448d9e9123a67db722109f behaviour
and use the two unused instructions in the trap vector to optimize a
bit.
Close #2651.
* Coding style cleanups.
* Use OS reserved trap 0x89 for IRQ Disable
* Use OS reserved trap 0x8A for IRQ Enable
* Add to SPARC CPU supplement documentation
This will result in faster Disable/Enable code since the
system trap handler does not need to decode which function
the user wants. Besides the IRQ disable/enabled can now
be inline which avoids the caller to take into account that
o0-o7+g1-g4 registers are destroyed by trap handler.
It was also possible to reduce the interrupt trap handler by
five instructions due to this.
Save five instructions on underflow handling.
By using an optimized trap entry we can move instructions from
the window underflow function into the trap entry vector. By
setting WIM=0 and using RESTORE it is possible to move the
new WIM register content from the trapped window into the
to-be-restored register window. It is then possible to avoid
the WIM write delay.
I see no need for waiting the 3 instruction delay for wim to be
written in this case, since the STD after does not depend on WIM
Now that a SPARC fatal handler is defined, we no longer
need the BSP specific reset routine.
Instead of calling the system call TA instruction directly it
is better paractise to isolate the trap implementation to the
system call functions.
BSP_fatal_exit() is added.
The last optimization missed was incorrect in regards to
PSR write instruction delay must be 3 instructions.
New optimizations:
* align to 32-byte cache line.
* rearrange code into three "blocks" of 4 instructions that
is executed by syscall 2 and 3. This is to optimize for
16/32 byte cache lines.
* use delay-slot instruction in trap table to reduce by one
instruction.
* use the fact that "wr %PSR" implements XOR to reduce by
one instruction.
Use __bss_start available via %g2 to clear the BSS section. The usage
of _edata resulted in a copy of [_edata, __bss_start) from ROM to RAM
and then a clear to zero of this area.
Clear now only [__bss_start, _end).
Use the register %g4 for the data content since it must be an even
numbered register due to the std/ldd. Use the register %g2 for the BSS
start address, so that it can be later re-used for the BSS zero loop.
Use a standard function for startup on secondary processors.
Use register g6 for the per-CPU control of the current processor. The
register g6 is reserved for the operating system by the SPARC ABI. On
Linux register g6 is used for a similar purpose with the same method
since 1996.
The register g6 must be initialized during system startup and then must
remain unchanged.
Since the per-CPU control is used in all critical sections of the
operating system, this is a performance optimization for the operating
system core procedures. An additional benefit is that the low-level
context switch and interrupt processing code is now identical on non-SMP
and SMP configurations.
Add _LEON3_Get_current_processor().
Avoid usage of the same stack area by multiple secondary processors at
the same time.
Avoid magic delay loops.
Add doxygen to the header files in sparc/shared/include directory.
