added clock cycles after GRSPW reset to make sure CTRL.START bit
write actually have an effect. Wait until reset is completed.
Update: Daniel Hellstrom updated SpW-IRQ implementation accoring to
changes in hardware register layout and features.
Both ioctl commands destroyed the control register by writing the
content of the status register into it.
This is to improve odds of getting a fast memcpy-operation.
This patch adds a new driver for the GRSPW SpaceWire AMBA
interface family. The new driver does not implement a standard
RTEMS driver, instead it provides only a library interface to
the GRSPW devices. This driver can be used to implement a
RTEMS I/O driver or used directly.
New features compared with old GRSPW driver:
* zero-copy packet interface
* possibility to send/receive mulitple packets per call
* optional interrupt awaken work-task to process TX/RX queues
* DMA channels support. Before only first DMA channel supported
* Separate DMA and link control
* Packet based error flags
Most drivers use the Driver Manager for device probing, they
work on AMBA-over-PCI systems if PCI is big-endian.
New APIs:
* GPIO Library, interfaced to GRGPIO
* GENIRQ, Generic interrupt service implementation helper
New GRLIB Drivers:
* ACTEL 1553 RT, user interface is similar to 1553 BRM driver
* GR1553 (1553 BC, RT and BM core)
* AHBSTAT (AHB error status core)
* GRADCDAC (Core interfacing to ADC/DAC hardware)
* GRGPIO (GPIO port accessed from GPIO Library)
* MCTRL (Memory controller settings configuration)
* GRETH (10/100/1000 Ethernet driver using Driver manager)
* GRPWM (Pulse Width Modulation core)
* SPICTRL (SPI master interface)
* GRSPW_ROUTER (SpaceWire Router AMBA configuration interface)
* GRCTM (SpaceCraft on-board Time Management core)
* SPWCUC (Time distribution over SpaceWire)
* GRTC (SpaceCraft up-link Tele core)
* GRTM (SpaceCraft down-link Tele Metry core)
GR712RC ASIC specific interfaces:
* GRASCS
* CANMUX (select between OCCAN and SATCAN)
* SATCAN
* SLINK
Some bugfixes at the same time. After this patch the drivers
may be used on RASTA systems having a big-endian PCI layout.
Removed not up to date changelogs, rely on git log instead.
The CCHIP driver is replaced with the GR_701 driver. The
RASTA driver is replaced by the GR-RASTA-IO driver.
All drivers are now compatible with both LEON2 and LEON3,
drivers were initialized directly by the PCI-board drivers
are now initialized by the driver manager and therefore
does not require the double code created by including for
example grcan.c into grcan_rasta.c. The other drivers needs
to be updated to the driver manager framework however.
Added support for:
* GR-701 (only LEON2 before)
* GR-RASTA-IO (only LEON2 before)
* GR-RASTA-ADCDAC
* GR-RASTA-TMTC
* GR-RASTA-SPW-ROUTER
* GR-TMTC-1553
The PCI and RASTA versions of the uart, spacewire and 1553 drivers directly includes the c-file of the standard versions
of the drivers, but uses a macro to change the name of the driver register function. When the standard version is
used this function should be global, when it is included as part of the PCI and RASTA versions it should be local and
static.
Some register layout definitions for LEON3 reside in ambapp.h which
does not really has anything to do with device registers. The
register structures has been incorrectly named LEON3_*, the cores
are not only used on LEON3 but on LEON4 and perhaps on LEON5 when
that day comes. Some structures has been renamed according to the
GRLIB core name instead, which CPU that actually use it is not
relevant. Drivers has been updated with the new names.
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
The drivers are updated to use the new AMBA layer, however the
backwards-compatibility interface (ambapp_old) is used.
* shared/1553/b1553brm.c, shared/can/grcan.c, shared/can/occan.c,
shared/spw/grspw.c, shared/uart/apbuart.c:
* shared/spw/grspw_rasta.c: Guard prototype of
grspw_rasta_calc_memoffs in #ifdef GRSPW_STATIC_MEM to avoid
warning.
* shared/include/grspw.h, shared/spw/grspw.c: GRSPW SpaceWire Driver.
Fixes typecast to volatile integer instead of to integer. Added
scanning for GRSPW2 Core, The GRSPW2 core is run in legacy mode.
* shared/spw/grspw.c: Remove include of sched.h. It does not appear to
be needed and is unavailable when POSIX is disabled.
* shared/can/grcan.c, shared/include/debug_defs.h, shared/spw/grspw.c:
Remove use of DEBUG_printf.
* shared/1553/b1553brm.c, shared/can/grcan.c, shared/can/grcan_rasta.c,
shared/can/occan.c, shared/spw/grspw.c, shared/spw/grspw_pci.c,
shared/uart/apbuart.c: Remove warnings.
New drivers: PCI, b1553BRM, SpaceWire(GRSPW), CAN (GRCAN,OC_CAN),
Raw UART.
* shared/1553/b1553brm.c, shared/1553/b1553brm_pci.c,
shared/1553/b1553brm_rasta.c, shared/can/grcan.c,
shared/can/grcan_rasta.c, shared/can/occan.c, shared/can/occan_pci.c,
shared/spw/grspw.c, shared/spw/grspw_pci.c, shared/spw/grspw_rasta.c,
shared/uart/apbuart.c, shared/uart/apbuart_pci.c,
shared/uart/apbuart_rasta.c: New files missed in previous commit.
