path: root/c/src/lib/libbsp/sparc/shared/spi/spictrl.c (unfollow)
2015-04-17DRVMGR: KEY_TYPE now a enum drvmgr_ktDaniel Hellstrom1-1/+1
2015-04-17sparc bsps: updated license to rtems.orgDaniel Hellstrom1-1/+1
2015-04-17LEON: move driver headers to bsp/ directoryDaniel Hellstrom1-1/+1
2015-04-17SPICTRL: fix build warningsDaniel Hellstrom1-10/+19
2015-04-17LEON: added new drivers to the LEON2/LEON3 BSPsDaniel Hellstrom1-0/+1008
Most drivers use the Driver Manager for device probing, they work on AMBA-over-PCI systems if PCI is big-endian. New APIs: * GPIO Library, interfaced to GRGPIO * GENIRQ, Generic interrupt service implementation helper New GRLIB Drivers: * ACTEL 1553 RT, user interface is similar to 1553 BRM driver * GR1553 (1553 BC, RT and BM core) * AHBSTAT (AHB error status core) * GRADCDAC (Core interfacing to ADC/DAC hardware) * GRGPIO (GPIO port accessed from GPIO Library) * MCTRL (Memory controller settings configuration) * GRETH (10/100/1000 Ethernet driver using Driver manager) * GRPWM (Pulse Width Modulation core) * SPICTRL (SPI master interface) * GRSPW_ROUTER (SpaceWire Router AMBA configuration interface) * GRCTM (SpaceCraft on-board Time Management core) * SPWCUC (Time distribution over SpaceWire) * GRTC (SpaceCraft up-link Tele core) * GRTM (SpaceCraft down-link Tele Metry core) GR712RC ASIC specific interfaces: * GRASCS * CANMUX (select between OCCAN and SATCAN) * SATCAN * SLINK
