The old code used a limited PCI configuration library, which was
duplicated into LEON2 and LEON3 BSP pci.c together with respective
Host controller PCI interface.
The LEON2 BSP had support for AT697 PCI, and LEON3 for GRPCI PCI
Host controller. With this update new PCI Host drivers are added,
and all support the new generic PCI Library:
* AT697 PCI (LEON2 only)
* GRPCI (LEON2-GRLIB and LEON3)
* GRPCI2 (LEON2-GRLIB and LEON3)
* Actel PCIF GRLIB Wrapper (LEON3 only)
The LEON2 BSP is defined as big-endian PCI in bsp.h, since the
AT697 supports only big-endian PCI.
+ libbsp/sparc/shared/include/pci.h was largely a copy of
an older version of the cpukit pci.h. Removed much of the
contents and included <rtems/pci.h>.
+ sparc/*/pci*.c - Move to <rtems/pci.h> required updating
to use uint32_t for dword accesses.
+ Rename PCI_MULTI_FUNCTION to PCI_HEADER_TYPE_MULTI_FUNCTION
+ Define PCI_HEADER_TYPE_MULTI_FUNCTION in cpukit pci.h and remove
PCI_MULTI_FUNCTION definitions in C files.
+ Move PCI_INVALID_VENDORDEVICEID definitions from various C files
to cpukit pci.h
* shared/pci/pcifinddevice.c: New file.
