Most drivers use the Driver Manager for device probing, they
work on AMBA-over-PCI systems if PCI is big-endian.
New APIs:
* GPIO Library, interfaced to GRGPIO
* GENIRQ, Generic interrupt service implementation helper
New GRLIB Drivers:
* ACTEL 1553 RT, user interface is similar to 1553 BRM driver
* GR1553 (1553 BC, RT and BM core)
* AHBSTAT (AHB error status core)
* GRADCDAC (Core interfacing to ADC/DAC hardware)
* GRGPIO (GPIO port accessed from GPIO Library)
* MCTRL (Memory controller settings configuration)
* GRETH (10/100/1000 Ethernet driver using Driver manager)
* GRPWM (Pulse Width Modulation core)
* SPICTRL (SPI master interface)
* GRSPW_ROUTER (SpaceWire Router AMBA configuration interface)
* GRCTM (SpaceCraft on-board Time Management core)
* SPWCUC (Time distribution over SpaceWire)
* GRTC (SpaceCraft up-link Tele core)
* GRTM (SpaceCraft down-link Tele Metry core)
GR712RC ASIC specific interfaces:
* GRASCS
* CANMUX (select between OCCAN and SATCAN)
* SATCAN
* SLINK
This allows it to be wrapped by another function at link-time
and can be used to trace interrupts. If not placed in a separate
file, the function pointer address used in BSP_shared_interrupt_init
will be resolved at compile-time, and the function will not be wrappable.
Changed LEON3_irq-mp to const also.
The LEON3_MP_IRQ define is used to pick the IRQ to be used by the
shared memory driver and for inter-processor interrupts. On some LEON3
systems, for example the GR712RC, the default value of 14 is not suitable.
To make this value configurable from the application, it is replaced with
a weakly linked variable that can be overridden from the application.
Basically the shared-irq handler overwrite the SMP/MP traphandler
previously initialized with set_vector(). That caused IPIs to enter
BSP spurious handler.
The implementation use IRQ number instead of vector number since
some IRQs does not have a unique vector, for example the extended
interrupts all enter the same trap vector entry.
Added support for the LEON3 extended interrupt controller when using
the shared IRQ layer.
ERC32 patches untested.
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
Regenerate
