+ libbsp/sparc/shared/include/pci.h was largely a copy of
an older version of the cpukit pci.h. Removed much of the
contents and included <rtems/pci.h>.
+ sparc/*/pci*.c - Move to <rtems/pci.h> required updating
to use uint32_t for dword accesses.
+ Rename PCI_MULTI_FUNCTION to PCI_HEADER_TYPE_MULTI_FUNCTION
+ Define PCI_HEADER_TYPE_MULTI_FUNCTION in cpukit pci.h and remove
PCI_MULTI_FUNCTION definitions in C files.
+ Move PCI_INVALID_VENDORDEVICEID definitions from various C files
to cpukit pci.h
Some register layout definitions for LEON3 reside in ambapp.h which
does not really has anything to do with device registers. The
register structures has been incorrectly named LEON3_*, the cores
are not only used on LEON3 but on LEON4 and perhaps on LEON5 when
that day comes. Some structures has been renamed according to the
GRLIB core name instead, which CPU that actually use it is not
relevant. Drivers has been updated with the new names.
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
The drivers are updated to use the new AMBA layer, however the
backwards-compatibility interface (ambapp_old) is used.
The old layer had some limitations/problems for multiple AHB
buses since the data structure containing all AMBA devices
were allocated before scanning.
The new layer create devices as they are found and memory is
allocated using malloc() or bsp_early_malloc() during booting.
The old 8 functions for finding a specific AHB-Slave or
APB-Slave device has been replaced with one function,
ambapp_for_each(), which iterates over all devices matching
the specified search options and calls a user provided
function. The new way lowers the footprint and makes searching
more flexible.
The frequency information is now supported, if the frequency
of one device is reported by the user.
More AHB-to-AHB bridges are supported.
The API has been split into several parts in order to lower the
footprint.
The API also introduces the AMBAPP CORE concept, where one
ambapp_core can be created from one AHB Master, AHB Slave
and one APB Slave, at least one device is required for creating
a core.
The implementation use IRQ number instead of vector number since
some IRQs does not have a unique vector, for example the extended
interrupts all enter the same trap vector entry.
Added support for the LEON3 extended interrupt controller when using
the shared IRQ layer.
ERC32 patches untested.
Regenerate
PR 1483/cpukit
* shared/include/pci.h: Rename pci_config into rtems_pci_config_t.
* shared/include/pci.h: Add prototypes for BusCountPCI(void),
init_pci(void).
* shared/include/pci.h: Revert extern inline patch.
* shared/include/pci.h: Change extern inline to static inline.
* shared/include/grcan_spwrtc.h: Removed.
* shared/include/ambapp.h: Sync head and 4.8 branch.
* shared/include/grspw.h, shared/spw/grspw.c: GRSPW SpaceWire Driver.
Fixes typecast to volatile integer instead of to integer. Added
scanning for GRSPW2 Core, The GRSPW2 core is run in legacy mode.
* shared/can/grcan.c, shared/can/grcan_rasta.c,
shared/include/ambapp.h: GRCAN CAN driver. Fixes Interrupt
enabling/disabling in the driver, interrupt may not be restored
correctly. Implements the baud rate calculation routine. Removed
unnecessary printk. Fixed scanning to support GRCAN and GRHCAN
hardware. Added GRCAN device number to ambapp.h.
* Makefile.am, shared/can/occan.c, shared/include/ambapp.h: Add initial
i2c and update OC-CAN support.
* shared/i2c/i2cmst.c, shared/include/i2cmst.h: New files.
* shared/can/grcan.c, shared/include/debug_defs.h, shared/spw/grspw.c:
Remove use of DEBUG_printf.
* Makefile.am: Add the following new drivers: PCI, b1553BRM,
SpaceWire(GRSPW), CAN (GRCAN,OC_CAN), Raw UART.
* shared/include/apbuart.h, shared/include/apbuart_pci.h,
shared/include/apbuart_rasta.h, shared/include/b1553brm.h,
shared/include/b1553brm_pci.h, shared/include/b1553brm_rasta.h,
shared/include/debug_defs.h, shared/include/grcan.h,
shared/include/grcan_rasta.h, shared/include/grcan_spwrtc.h,
shared/include/grspw.h, shared/include/grspw_pci.h,
shared/include/grspw_rasta.h, shared/include/occan.h,
shared/include/occan_pci.h, shared/include/pci.h: New files.
* shared/amba/ambapp.c, shared/include/ambapp.h: New files.
