path: root/c/src/lib/libbsp/sparc/shared/include/gr_rasta_adcdac.h (follow)
* LEON: updated and added PCI peripherals for LEON BSPsDaniel Hellstrom2015-04-171-0/+49
The CCHIP driver is replaced with the GR_701 driver. The RASTA driver is replaced by the GR-RASTA-IO driver. All drivers are now compatible with both LEON2 and LEON3, drivers were initialized directly by the PCI-board drivers are now initialized by the driver manager and therefore does not require the double code created by including for example grcan.c into grcan_rasta.c. The other drivers needs to be updated to the driver manager framework however. Added support for: * GR-701 (only LEON2 before) * GR-RASTA-IO (only LEON2 before) * GR-RASTA-ADCDAC * GR-RASTA-TMTC * GR-RASTA-SPW-ROUTER * GR-TMTC-1553
