* | bsps/sparc: Add common gnat handler function prototype. | Daniel Cederman | 2014-03-24 | 1 | -0/+1 |
| | | | | Moved prototype for __gnat_install_handler and __gnat_install_handler_common to common header file. Placed header file in bsp namespace. | ||||
* | libbsp/sparc/.../gnatcommon.c: Formatting | Joel Sherrill | 2013-09-30 | 1 | -7/+5 |
* | #include <unistd.h>. | Ralf Corsepius | 2010-04-02 | 1 | -0/+2 |
* | 2007-05-09 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-05-09 | 1 | -3/+4 |
| | | | | | * shared/bspstart.c, shared/gnatcommon.c: Remove debug print methods that are redundant with prntk and replace their use with printk. | ||||
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-21 | 1 | -2/+2 |
* | 2004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-31 | 1 | -4/+4 |
| | | | | * bspstart.c, gnatcommon.c: Convert to using c99 fixed size types. | ||||
* | 2002-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-01 | 1 | -0/+1 |
| | | | | * gnatcommon.c: Removed warnings. | ||||
* | 2000-11-13 Jiri Gaisler <jgais@ws.estec.esa.nl> | Joel Sherrill | 2000-11-13 | 1 | -0/+114 |
* ChangeLog, .cvsignore, Makefile.am, bspclean.c, bspstart.c, gnatcommon.c, start.S: New files. Largely moved from ERC32 BSP to be able to be shared with LEON and other SPARC BSPs. |
