Some bugfixes at the same time. After this patch the drivers
may be used on RASTA systems having a big-endian PCI layout.
Removed not up to date changelogs, rely on git log instead.
Some register layout definitions for LEON3 reside in ambapp.h which
does not really has anything to do with device registers. The
register structures has been incorrectly named LEON3_*, the cores
are not only used on LEON3 but on LEON4 and perhaps on LEON5 when
that day comes. Some structures has been renamed according to the
GRLIB core name instead, which CPU that actually use it is not
relevant. Drivers has been updated with the new names.
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
The drivers are updated to use the new AMBA layer, however the
backwards-compatibility interface (ambapp_old) is used.
* shared/can/occan.c: Comment out unused var "tmp".
* shared/1553/b1553brm.c, shared/can/grcan.c, shared/can/occan.c,
shared/spw/grspw.c, shared/uart/apbuart.c:
* shared/can/occan.c: LEON2/3 OCCAN CAN driver. Fixes typecast to
volatile integer where needed. Fixes bug where closing the driver and
opening it again could make the driver not starting transmission due
to the software fifo was not cleared.
* Makefile.am, shared/can/occan.c, shared/include/ambapp.h: Add initial
i2c and update OC-CAN support.
* shared/i2c/i2cmst.c, shared/include/i2cmst.h: New files.
* shared/can/occan.c: Fix warning on Diab compiler.
* shared/can/occan.c: Fix Reenable command and fix typo.
* shared/1553/b1553brm.c, shared/can/grcan.c, shared/can/grcan_rasta.c,
shared/can/occan.c, shared/spw/grspw.c, shared/spw/grspw_pci.c,
shared/uart/apbuart.c: Remove warnings.
New drivers: PCI, b1553BRM, SpaceWire(GRSPW), CAN (GRCAN,OC_CAN),
Raw UART.
* shared/1553/b1553brm.c, shared/1553/b1553brm_pci.c,
shared/1553/b1553brm_rasta.c, shared/can/grcan.c,
shared/can/grcan_rasta.c, shared/can/occan.c, shared/can/occan_pci.c,
shared/spw/grspw.c, shared/spw/grspw_pci.c, shared/spw/grspw_rasta.c,
shared/uart/apbuart.c, shared/uart/apbuart_pci.c,
shared/uart/apbuart_rasta.c: New files missed in previous commit.
