Most drivers use the Driver Manager for device probing, they
work on AMBA-over-PCI systems if PCI is big-endian.
New APIs:
* GPIO Library, interfaced to GRGPIO
* GENIRQ, Generic interrupt service implementation helper
New GRLIB Drivers:
* ACTEL 1553 RT, user interface is similar to 1553 BRM driver
* GR1553 (1553 BC, RT and BM core)
* AHBSTAT (AHB error status core)
* GRADCDAC (Core interfacing to ADC/DAC hardware)
* GRGPIO (GPIO port accessed from GPIO Library)
* MCTRL (Memory controller settings configuration)
* GRETH (10/100/1000 Ethernet driver using Driver manager)
* GRPWM (Pulse Width Modulation core)
* SPICTRL (SPI master interface)
* GRSPW_ROUTER (SpaceWire Router AMBA configuration interface)
* GRCTM (SpaceCraft on-board Time Management core)
* SPWCUC (Time distribution over SpaceWire)
* GRTC (SpaceCraft up-link Tele core)
* GRTM (SpaceCraft down-link Tele Metry core)
GR712RC ASIC specific interfaces:
* GRASCS
* CANMUX (select between OCCAN and SATCAN)
* SATCAN
* SLINK
The expression "*pi++" post-increments the pointer (not the value).
The old layer had some limitations/problems for multiple AHB
buses since the data structure containing all AMBA devices
were allocated before scanning.
The new layer create devices as they are found and memory is
allocated using malloc() or bsp_early_malloc() during booting.
The old 8 functions for finding a specific AHB-Slave or
APB-Slave device has been replaced with one function,
ambapp_for_each(), which iterates over all devices matching
the specified search options and calls a user provided
function. The new way lowers the footprint and makes searching
more flexible.
The frequency information is now supported, if the frequency
of one device is reported by the user.
More AHB-to-AHB bridges are supported.
The API has been split into several parts in order to lower the
footprint.
The API also introduces the AMBAPP CORE concept, where one
ambapp_core can be created from one AHB Master, AHB Slave
and one APB Slave, at least one device is required for creating
a core.
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
* shared/amba/ambapp.c, shared/include/ambapp.h: New files.
