* | bsps/sparc: Make local functions static. | Daniel Cederman | 2014-03-21 | 1 | -0/+3 |
| | | | | | | | The PCI and RASTA versions of the uart, spacewire and 1553 drivers directly includes the c-file of the standard versions of the drivers, but uses a macro to change the name of the driver register function. When the standard version is used this function should be global, when it is included as part of the PCI and RASTA versions it should be local and static. | ||||
* | LEON: updated drivers to use new AMBAPP Layer | Daniel Hellstrom | 2012-04-17 | 1 | -1/+1 |
| | | | | | | | The drivers are updated to use the new AMBA layer, however the backwards-compatibility interface (ambapp_old) is used. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-11-29 | 1 | -9/+9 |
* | 2007-09-06 Daniel Hellstrom <daniel@gaisler.com> | Joel Sherrill | 2007-09-06 | 1 | -0/+132 |
New drivers: PCI, b1553BRM, SpaceWire(GRSPW), CAN (GRCAN,OC_CAN), Raw UART. * shared/1553/b1553brm.c, shared/1553/b1553brm_pci.c, shared/1553/b1553brm_rasta.c, shared/can/grcan.c, shared/can/grcan_rasta.c, shared/can/occan.c, shared/can/occan_pci.c, shared/spw/grspw.c, shared/spw/grspw_pci.c, shared/spw/grspw_rasta.c, shared/uart/apbuart.c, shared/uart/apbuart_pci.c, shared/uart/apbuart_rasta.c: New files missed in previous commit. |
