* configure.ac: Add BSPOPTS_*(NO_TABLE_MOVE).
Add BSPOPTS_*(FPU_REVB).
* wrapup/Makefile.am: Add tbr.
* gnatsupp/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.ac: Remove NETWORKING support.
* wrapup/Makefile.am: Remove NETWORKING support.
* configure.ac: Add RTEMS_BSPOPTS*(CONSOLE_USE_INTERRUPTS).
Add RTEMS_BSPOPTS*(SIMSPARC_FAST_IDLE).
Remove RTEMS_OUTPUT_BUILD_SUBDIRS.
* include/bsp.h: include bspopts.h.
This fix is in response to test results reported by Jerry Needell
<jerry.needell@unh.edu> for the SPARC/ERC32 and tracked as PR80.
* include/bsp.h: TM27 was not running properly because the ERC32
and LEON cannot nest interrupts at the same level. The BSP test support
had to be modified to support using two different interrupt sources.
* clock/ckinit.c, console/console.c, include/bsp.h, include/leon.h,
startup/setvec.c, timer/timer.c: Fixed typo.
* configure.in: Remove.
* ChangeLog: New file.
* console/debugputs.c: Switched to unsigned characters.
* console/console.c: Removed console_reserve_resources().
* include/Makefile.am: Cleanup.
* wrapup/Makefile.am: Pick up cache code from libcpu and pick
up .o's instead of .rel's from libcpu.
* startup/boardinit.S: St 32-bit ram width by default.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs,
configure.in, times, clock/.cvsignore, clock/Makefile.am,
clock/ckinit.c, console/.cvsignore, console/Makefile.am,
console/console.c, console/consolereserveresources.c,
console/debugputs.c, gnatsupp/.cvsignore,
gnatsupp/Makefile.am, gnatsupp/gnatsupp.c,
include/coverhd.h, include/leon.h, start/.cvsignore,
start/Makefile.am, startup/.cvsignore, startup/Makefile.am,
startup/boardinit.S, startup/linkcmds, startup/setvec.c,
startup/spurious.c, timer/.cvsignore, timer/Makefile.am,
timer/timer.c, tools/.cvsignore, tools/Makefile.am,
tools/configure.in, tools/runtest.in, wrapup/.cvsignore,
wrapup/Makefile.am: New file.
