Reflect changes to bsp.am.
* bsp_specs: Remove *lib:.
* clock/ckinit.c, console/console.c, console/consolereserveresources.c,
console/debugputs.c, include/bsp.h, include/coverhd.h,
include/leon.h, startup/setvec.c, timer/timer.c: URL for license
changed.
PR 477/networking
* Makefile.am, configure.ac, console/console.c, include/bsp.h,
startup/setvec.c, wrapup/Makefile.am: Add network support and enable
custom power down.
* leon_open_eth/.cvsignore, leon_open_eth/Makefile.am,
leon_open_eth/leon_open_eth.c: New files.
* Makefile.am: Install to @RTEMS_BSP@/tests.
* include/bsp.h: Correct copyright statements.
gnatsupp/Makefile.am: Reflect having moved automake.
* runtest.in: Add fileio to list of interactive tests.
* startup/Makefile.am: Remove USE_INIT_FINI.
* startup/linkcmds*: Add FreeBSD sysctl() sections.
* gnatsupp/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* gnatsupp/gnatsupp.c, startup/spurious.c: Removed warnings.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* gnatsupp/Makefile.am: Use .$(OBJEXT) instead of .o.
* Makefile.am: Add transform and bsptools_bindir hacks.
* configure.ac: Add RTEMS_ENV_RTEMSBSP.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* configure.ac: Remove BSPOPTS_*(NO_TABLE_MOVE).
Remove BSPOPTS_*(FPU_REVB).
* wrapup/Makefile.am: Remove tbr.
* configure.ac: Add BSPOPTS_*(NO_TABLE_MOVE).
Add BSPOPTS_*(FPU_REVB).
* wrapup/Makefile.am: Add tbr.
* gnatsupp/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.ac: Remove NETWORKING support.
* wrapup/Makefile.am: Remove NETWORKING support.
* configure.ac: Add RTEMS_BSPOPTS*(CONSOLE_USE_INTERRUPTS).
Add RTEMS_BSPOPTS*(SIMSPARC_FAST_IDLE).
Remove RTEMS_OUTPUT_BUILD_SUBDIRS.
* include/bsp.h: include bspopts.h.
This fix is in response to test results reported by Jerry Needell
<jerry.needell@unh.edu> for the SPARC/ERC32 and tracked as PR80.
* include/bsp.h: TM27 was not running properly because the ERC32
and LEON cannot nest interrupts at the same level. The BSP test support
had to be modified to support using two different interrupt sources.
* clock/ckinit.c, console/console.c, include/bsp.h, include/leon.h,
startup/setvec.c, timer/timer.c: Fixed typo.
* configure.in: Remove.
* ChangeLog: New file.
