Update #3285.
Update #3387.
Update #3285.
Update #3285.
This was used by the not supported "make dist".
Update #3285.
Update #3285.
upgrade to that version.
Close #3387.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
This was at the request of a user to make it easier to have a
custom entry point. This way they just provide their own top
level linkcmds and include linkcmds.base.
Updates #3520.
Update #3285.
* bsps/shared/cache
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Updates #3520.
This is necessary to pick up mandatory flags provided by the build
system.
Update #3254.
Update #3254.
Update #3260.
Update #3269.
Update #3254.
EXTRA_DIST += foobar
in fragments.
Update #3254.
Update #3254.
Updates #3520.
In case no clock driver is configured, the corresponding timer may be
stopped.
Updates #3520.
Patch was not intended to be pushed yet.
Updates #3520.
Done:
arm
bfin
epiphany
i386
lm32
m32c
mips
moxie
nios2
or1k
powerpc
riscv
sh
sparc
sparc64
v850
To do:
m68k
Differences noted:
+ endfile was sometimes before startfile
+ endfile sometimes was hard-coded and did not have -qrtems version
+ Should -e XXX (e.g. entry point) be in linkcmds?
+ Should -u XXX (e.g. undefined symbols) be in linkcmds?
+ Typos: Odd spacing, "old_endfiles" typo, and *(old_endfiles) (not %)
+ nios2: Referenced crtnn.o not crtn.o (error)
Need to revisit:
+ m32c, moxie, sparc64 includes !nostdlib which is not used elsewhere
+ sh has -EL/-EB mapping. Why needed?
+ sparc64 didn't include crti.o/crtn.o but it is part of toolset
+ v850 uses something like this for link and end_file:
"%{qrtems: %(old_link)}"
This means that these are unnecessary. Try this on all.
+ mips uses old_link all the time also.
+ arm/tms750 adds -EB.
+ powerpc: Why do we have rtems_crt* and not use something from GCC?
Updates #3520.
Updates #3250.
maintain.
Update #3254.
BSP_PRESS_KEY_FOR_RESET=0
BSP_RESET_BOARD_AT_EXIT=1
BSP_PRINT_EXCEPTION_CONTEXT=1
Update #3239.
According to data sheet bit 31 in ASR22 must be written with a zero
to start the up-counter. GRMON starts the up-counter for us. This
patch is important when running in "flight" from ROM without GRMON.
Remove old ISR parameter since is not used by the clock driver shell.
Make an implementation optional.
Update #3139.
Update #2355
The GRSPW packet driver supports SMP and therefore the legacy GRSPW
driver is disabled for SMP builds.
Update #2355
Update #2133.
The SPARC ABI is a bit special with respect to the floating point context.
The complete floating point context is volatile. Thus, from an ABI point
of view nothing needs to be saved and restored during a context switch.
Instead the floating point context must be saved and restored during
interrupt processing. Historically, the deferred floating point switch was
used for SPARC and the complete floating point context is saved and
restored during a context switch to the new floating point unit owner.
This is a bit dangerous since post-switch actions (e.g. signal handlers)
and context switch extensions may silently corrupt the floating point
context.
The floating point unit is disabled for interrupt handlers. Thus, in case
an interrupt handler uses the floating point unit then this will result in a
trap (INTERNAL_ERROR_ILLEGAL_USE_OF_FLOATING_POINT_UNIT).
In uniprocessor configurations, a lazy floating point context switch is
used. In case an active floating point thread is interrupted (PSR[EF] == 1)
and a thread dispatch is carried out, then this thread is registered as the
floating point owner. When a floating point owner is present during a
context switch, the floating point unit is disabled for the heir thread
(PSR[EF] == 0). The floating point disabled trap checks that the use of the
floating point unit is allowed and saves/restores the floating point context
on demand.
Update #3077.
Add new fatal error INTERNAL_ERROR_ILLEGAL_USE_OF_FLOATING_POINT_UNIT.
Update #3077.
Rename NGMP to GR740 and add configs for UT699, UT700, and GR712RC
The UT699 requires -mcpu=leon as it does not support the CAS instruction
provided by -mcpu=leon3. It also requires -mfix-ut699 for errata fixes.
UT700 and GR712RC requires the -mfix-ut700 and -mfix-gr712rc flags that
have been recently added to GCC's master and 7-branch.
Remove -msoft-float from the leon3 config to make the more common case
of using the FPU the default.
Update #3057.
Update #3071.
Close #3071.
This driver was initially intended for APBUART access on GRLIB PCI
peripherals (AMBA-over-PCI). There are already many APBUART drivers
for LEON. Instead of using this one the termios APBUART should work
on AMBA-over-PCI systems with recent changes on LEON3, however that
has not been tested yet.
Prefix BSP specific symbols with BSP name:
dbg_uart -> leon3_debug_uart
debug_uart_index -> leon3_debug_uart_index
