Interrupts have not been test yet
This patch adds a new driver for the GRSPW SpaceWire AMBA
interface family. The new driver does not implement a standard
RTEMS driver, instead it provides only a library interface to
the GRSPW devices. This driver can be used to implement a
RTEMS I/O driver or used directly.
New features compared with old GRSPW driver:
* zero-copy packet interface
* possibility to send/receive mulitple packets per call
* optional interrupt awaken work-task to process TX/RX queues
* DMA channels support. Before only first DMA channel supported
* Separate DMA and link control
* Packet based error flags
Most drivers use the Driver Manager for device probing, they
work on AMBA-over-PCI systems if PCI is big-endian.
New APIs:
* GPIO Library, interfaced to GRGPIO
* GENIRQ, Generic interrupt service implementation helper
New GRLIB Drivers:
* ACTEL 1553 RT, user interface is similar to 1553 BRM driver
* GR1553 (1553 BC, RT and BM core)
* AHBSTAT (AHB error status core)
* GRADCDAC (Core interfacing to ADC/DAC hardware)
* GRGPIO (GPIO port accessed from GPIO Library)
* MCTRL (Memory controller settings configuration)
* GRETH (10/100/1000 Ethernet driver using Driver manager)
* GRPWM (Pulse Width Modulation core)
* SPICTRL (SPI master interface)
* GRSPW_ROUTER (SpaceWire Router AMBA configuration interface)
* GRCTM (SpaceCraft on-board Time Management core)
* SPWCUC (Time distribution over SpaceWire)
* GRTC (SpaceCraft up-link Tele core)
* GRTM (SpaceCraft down-link Tele Metry core)
GR712RC ASIC specific interfaces:
* GRASCS
* CANMUX (select between OCCAN and SATCAN)
* SATCAN
* SLINK
The CCHIP driver is replaced with the GR_701 driver. The
RASTA driver is replaced by the GR-RASTA-IO driver.
All drivers are now compatible with both LEON2 and LEON3,
drivers were initialized directly by the PCI-board drivers
are now initialized by the driver manager and therefore
does not require the double code created by including for
example grcan.c into grcan_rasta.c. The other drivers needs
to be updated to the driver manager framework however.
Added support for:
* GR-701 (only LEON2 before)
* GR-RASTA-IO (only LEON2 before)
* GR-RASTA-ADCDAC
* GR-RASTA-TMTC
* GR-RASTA-SPW-ROUTER
* GR-TMTC-1553
The old code used a limited PCI configuration library, which was
duplicated into LEON2 and LEON3 BSP pci.c together with respective
Host controller PCI interface.
The LEON2 BSP had support for AT697 PCI, and LEON3 for GRPCI PCI
Host controller. With this update new PCI Host drivers are added,
and all support the new generic PCI Library:
* AT697 PCI (LEON2 only)
* GRPCI (LEON2-GRLIB and LEON3)
* GRPCI2 (LEON2-GRLIB and LEON3)
* Actel PCIF GRLIB Wrapper (LEON3 only)
The LEON2 BSP is defined as big-endian PCI in bsp.h, since the
AT697 supports only big-endian PCI.
This patch reimplements the console driver of the LEON3 BSP, it
has split up the console driver in two parts: Console driver and
UART driver. Before the only UART supported was APBUART and only
on-chip APBUARTs found during startup. However splitting the
driver in two allows any UART interface to reuse the termios
attach code of the console driver, pratically this has always
been a problem when discovering APBUARTs after startup for
example the PCI board GR-RASTA-IO has APBUARTs and must wait
until after PCI has been setup.
Since the only current driver that supports the new console
driver uses the Driver Manager, the new console driver is
only enabled when Driver Manager is initialized during startup.
The new APBUART driver supports:
* polling mode
* interrupt mode
* task-driven mode
* set UART attributes
* read UART attributes (system console inherit settings from
boot loader)
* Driver manager for finding/initialization of the hardware
With this patch the LEON family can access the GRLIB GPTIMER using
the Timer library (TLIB).
A System Clock driver instead of BSP/clock/ck_init.c is provided
using the TLIB. The classic clock driver is split in two parts,
clock driver and timer driver. The BSPs need only to fullfill the
timer interface instead of the clock interface. Currently only
LEON3 uses it. The LEON2 Timer is not ported to TLIB.
The GPTIMER driver is implemented using the Driver Manager, so the
System Clock Driver is at this point only suitable for LEON3 when
the driver manager is initialized during BSP startup. When the DrvMgr
is not initialized during startup the standard BSP/clock dirver is
used.
LEON2 sometimes also needs to access GPTIMER when a off-chip GRLIB AMBA
systems is connected, for example AMBA-over-PCI.
Remove support for using the second timer for time stamping.
Instead the user can configure the system clock timer to a higher
base clock frequency (lower the prescaler). This change does not
affect the GR712RC or LEON4-N2X. The GR712RC does not have two
GPTIMERs and the N2X uses the Interrupt Controller for time
stamping.
Bow that the AMBA initialization code exports the AMBA device,
the frequency can be obtained without an additional AMBA PnP
scanning.
Its now possible to select which timer core will be used for
system clock timer and to control the timer prescaler that
affects all timer instances on that timer core.
The timer and interrupt controller AMBA devices are exported
to make it possible for other code to get detailed information.
For example the frequency of the timer and interrupt controller
is required by the cpucounter support.
No point in scanning for the same GPTIMER twice. Rely on
amba.c AMBA PnP scanning.
Last timer instance of GPTIMER is sometimes a watchdog timer that
can reset the system on timer underflow.
Update #2268.
This allows it to be wrapped by another function at link-time
and can be used to trace interrupts. If not placed in a separate
file, the function pointer address used in BSP_shared_interrupt_init
will be resolved at compile-time, and the function will not be wrappable.
Fixes bug introduced with dff1803cfbec3775fff1b9c34cc707c05494dc3b.
The dummy.c was a de-facto default configuration. Rename it to
default-configuration.c. Use unlimited objects and the stack checker.
This makes it easier for new RTEMS users which will likely use this file
if they just work with the usual main() function as the application
entry point. Provide proper arguments for main() using the BSP command
line. Add spare user extensions and drivers.
Do not initialize the network by default. Delete bspinit.c.
* Coding style cleanups.
* Use OS reserved trap 0x89 for IRQ Disable
* Use OS reserved trap 0x8A for IRQ Enable
* Add to SPARC CPU supplement documentation
This will result in faster Disable/Enable code since the
system trap handler does not need to decode which function
the user wants. Besides the IRQ disable/enabled can now
be inline which avoids the caller to take into account that
o0-o7+g1-g4 registers are destroyed by trap handler.
It was also possible to reduce the interrupt trap handler by
five instructions due to this.
Condition needs to be inverted, as a 1 in the mask register means
that the interrupt is enabled. Solves ticket #1958 in trac.
This option is necessary to use the latest GCC 4.8, 4.9 and 5.0
versions.
Provide it also if RTEMS_MULTIPROCESSING is defined.
Check that data cache snooping exists and is enabled on all cores.
Manupilating the interrupt control registers directly instead
of going through the interrupt layer can be deceiving.
Changed LEON3_irq-mp to const also.
The LEON2 and ERC32 maps the new macros to CPU0 since they do not
support SMP. With the LEON3 a specific CPU's interrupt controller
registers can be modified using macros.
Move interrupt lock to device context and expose only this structure to
the read, write and set attributes device handler. This makes these
device handler independent of the general Termios infrastructure
suitable for direct use in printk() support.
By removing the bsp_reset() mechanism and instead relying on the
CPU_Fatal_halt() routine SMP and single-core can halt by updating
the _Internal_errors_What_happened structure and set the state to
SYSTEM_STATE_TERMINATED (the generic way). This will be better
for test scripts and debugger that can generically look into why
the OS stopped.
For SMP systems, only the fatal-reporting CPU waits until all other
CPUs are powered down (with a time out of one clock tick). The
reason why a fatal stop happend may be because CPU0 was soft-locked
up so we can never trust that CPU0 should do the halt for us.
The Fatal_halt handler now have two options, either halt
as before or enter system error state to return to
debugger or simulator. The exit-code is now also
propagated to the debugger which is very useful for
testing.
The CPU_Fatal_halt handler was split up into two, since
the only the LEON3 support the CPU power down.
The LEON3 halt now uses the power-down instruction to save
CPU power. This doesn't stop a potential watch-dog timer
from expiring.
Instead of calling the system call TA instruction directly it
is better paractise to isolate the trap implementation to the
system call functions.
BSP_fatal_exit() is added.
The LEON3_MP_IRQ define is used to pick the IRQ to be used by the
shared memory driver and for inter-processor interrupts. On some LEON3
systems, for example the GR712RC, the default value of 14 is not suitable.
To make this value configurable from the application, it is replaced with
a weakly linked variable that can be overridden from the application.
