* | Cleanup. | Ralf Corsepius | 2008-07-14 | 1 | -6/+0 |
* | 2008-03-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-03-11 | 2 | -1/+5 |
| | | | | * runtest.in: Skip all fatal error tests. | ||||
* | 2007-09-04 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-09-04 | 2 | -1/+6 |
| | | | | | * runtest.in: Add capture to list of interative tests to skip in batch mode. | ||||
* | 2007-05-11 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-05-11 | 2 | -8/+12 |
| | | | | * runtest.in: Now tries to work with tsim. | ||||
* | 2007-04-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2007-04-17 | 1 | -1/+1 |
| | | | | | * erc32/tools/runtest.in, leon2/tools/runtest.in, leon3/tools/runtest.in: Do not run pppd.exe from batch mode script. | ||||
* | 2007-01-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-01-26 | 2 | -1/+5 |
| | | | | * Makefile.am: Use MKDIR_P instead of mkdir_p. | ||||
* | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-12-02 | 2 | -1/+5 |
| | | | | * configure.ac: New BUG-REPORT address. | ||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 2 | -2/+6 |
| | | | | * configure.ac: Require autoconf-2.60. Require automake-1.10. | ||||
* | Backport from rtems-4-6-branch. | Ralf Corsepius | 2006-01-09 | 4 | -0/+378 |
* | 2006-01-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-09 | 1 | -0/+4 |
* Makefile.am, runtest.in, configure.ac: Backport from rtems-4-6-branch. |
