Update #3285.
This was at the request of a user to make it easier to have a
custom entry point. This way they just provide their own top
level linkcmds and include linkcmds.base.
Updates #3520.
Rename NGMP to GR740 and add configs for UT699, UT700, and GR712RC
The UT699 requires -mcpu=leon as it does not support the CAS instruction
provided by -mcpu=leon3. It also requires -mfix-ut699 for errata fixes.
UT700 and GR712RC requires the -mfix-ut700 and -mfix-gr712rc flags that
have been recently added to GCC's master and 7-branch.
Remove -msoft-float from the leon3 config to make the more common case
of using the FPU the default.
Update #3057.
* startup/linkcmds: Include basic linker command file and define only
board specific values. Define RAM and PROM limits only if not defined
by command line arguments.
* Makefile.am, preinstall.am: Reflect changes above.
* startup/linkcmds: Start of RTEMS Work Area must be on 16 byte
boundary on the SPARC.
PR 1390/bsps
* startup/linkcmds: Fix sections so C++ global constructors and
destructors work with late model (>= 4.3) gcc versions.
* startup/linkcmds: All SPARC executables should include
rtems_get_version_string so the monitor used can provide RTEMS
awareness based upon the version.
* startup/linkcmds: Add wildcard to gcc_except_table section so
programs compiled with gcc 4.3.x can link.
* startup/linkcmds: Handle .data.* sections
* startup/linkcmds: Add .rela.dyn sections.
* startup/linkcmds: Add .gnu.linkonce.b.* section.
* startup/linkcmds: Add sections required by newer gcc versions.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs,
configure.in, times, clock/.cvsignore, clock/Makefile.am,
clock/ckinit.c, console/.cvsignore, console/Makefile.am,
console/console.c, console/consolereserveresources.c,
console/debugputs.c, gnatsupp/.cvsignore,
gnatsupp/Makefile.am, gnatsupp/gnatsupp.c,
include/coverhd.h, include/leon.h, start/.cvsignore,
start/Makefile.am, startup/.cvsignore, startup/Makefile.am,
startup/boardinit.S, startup/linkcmds, startup/setvec.c,
startup/spurious.c, timer/.cvsignore, timer/Makefile.am,
timer/timer.c, tools/.cvsignore, tools/Makefile.am,
tools/configure.in, tools/runtest.in, wrapup/.cvsignore,
wrapup/Makefile.am: New file.
+ interrupt masking correction
+ FPU rev.B workaround
+ minor erc32 related fixes
to support a.out and ELF.
commit them.
