Add _LEON3_Get_current_processor().
Add and use _SMP_Get_current_processor() and
rtems_smp_get_current_processor().
Delete bsp_smp_interrupt_cpu().
Change type of current processor index from int to uint32_t to match
_SMP_Processor_count type.
* smp/getcpuid.c: Fix header from accidental and irrelevant copy and
paste.
Jennifer Averett <jennifer.averett@OARcorp.com>
PR 1801/bsps
* Makefile.am, include/leon.h: Add SMP support to LEON3 BSP.
* smp/getcpuid.c, smp/smp_leon3.c: New files.
