line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Add doxygen to the bsp.h, tm27.h, amba.h and leon.h files
* amba/amba.c, include/tm27.h, shmsupp/lock.c, startup/bspstart.c,
startup/spurious.c:
PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* include/tm27.h: New.
