Moved prototype for __gnat_install_handler and __gnat_install_handler_common to common header file. Placed header file in bsp namespace.
The PCI and RASTA versions of the uart, spacewire and 1553 drivers directly includes the c-file of the standard versions
of the drivers, but uses a macro to change the name of the driver register function. When the standard version is
used this function should be global, when it is included as part of the PCI and RASTA versions it should be local and
static.
Also signal to compiler that the start variable in lan91cxx_recv is only used when debugging.
The SPARC processors supported by RTEMS have no built-in CPU counter
support. We have to use some hardware counter module for this purpose.
The BSP must provide a 32-bit register which contains the current CPU
counter value and a function for the difference calculation. It can use
for example the GPTIMER instance used for the clock driver.
Add doxygen to the header files in sparc/shared/include directory.
Add doxygen to the cchip.c & leon_open_eth.c files.
sparc/shared/startup/bspgetworkarea.c
* refactored sparc/shared/bspgetworkarea.c to sparc/shared/startup/bspgetworkarea.c
This reduces the size of the RTEMS tests on average about 45%.
Delete bsp_smp_wait_for(). Other parts of the system work without
timeout, e.g. the spinlocks. Using a timeout here does not make the
system more robust.
Delete bsp_smp_cpu_state and replace it with Per_CPU_State. The
Per_CPU_State follows the Score naming conventions. Add
_Per_CPU_Change_state() and _Per_CPU_Wait_for_state() functions to
change and observe states.
Use Per_CPU_State in Per_CPU_Control instead of the anonymous integer.
Add _CPU_Processor_event_broadcast() and _CPU_Processor_event_receive()
functions provided by the CPU port. Use these functions in
_Per_CPU_Change_state() and _Per_CPU_Wait_for_state().
Add prototype for _SMP_Send_message().
Delete RTEMS_BSP_SMP_FIRST_TASK message. The first context switch is
now performed in rtems_smp_secondary_cpu_initialize(). Issuing the
first context switch in the context of the inter-processor interrupt is
not possible on systems with a modern interrupt controller. Such an
interrupt controler usually requires a handshake protocol with interrupt
acknowledge and end of interrupt signals. A direct context switch in an
interrupt handler circumvents the interrupt processing epilogue and may
leave the system in an inconsistent state.
Release lock in rtems_smp_process_interrupt() even if no message was
delivered. This prevents deadlock of the system.
Simplify and format _SMP_Send_message(),
_SMP_Request_other_cores_to_perform_first_context_switch(),
_SMP_Request_other_cores_to_dispatch() and
_SMP_Request_other_cores_to_shutdown().
Add CPU port type CPU_Exception_frame and function
_CPU_Exception_frame_print().
The CPU ports of avr, bfin, h8300, lm32, m32c, m32r, m68k, nios2, sh,
sparc64, and v850 use an empty default implementation of
Add rtems_exception_frame and rtems_exception_frame_print().
Add RTEMS_FATAL_SOURCE_EXCEPTION for CPU exceptions. Use rtems_fatal()
with source RTEMS_FATAL_SOURCE_EXCEPTION in CPU ports of i386, powerpc,
and sparc for unexpected exceptions.
Add third parameter to RTEMS_BSP_CLEANUP_OPTIONS() which controls the
BSP_PRINT_EXCEPTION_CONTEXT define used in the default
bsp_fatal_extension().
Add test sptests/spfatal26.
The bsp_fatal_extension() will call BSP_fatal_return().
The work areas (RTEMS work space and C program heap) will be initialized
now in a separate step and are no longer part of
rtems_initialize_data_structures(). Initialization is performed with
tables of Heap_Area entries. This allows usage of scattered memory
areas present on various small scale micro-controllers.
The sbrk() support API changes also. The bsp_sbrk_init() must now deal
with a minimum size for the first memory chunk to take the configured
work space size into account.
Conflicts:
+ libbsp/sparc/shared/include/pci.h was largely a copy of
an older version of the cpukit pci.h. Removed much of the
contents and included <rtems/pci.h>.
+ sparc/*/pci*.c - Move to <rtems/pci.h> required updating
to use uint32_t for dword accesses.
+ Rename PCI_MULTI_FUNCTION to PCI_HEADER_TYPE_MULTI_FUNCTION
+ Define PCI_HEADER_TYPE_MULTI_FUNCTION in cpukit pci.h and remove
PCI_MULTI_FUNCTION definitions in C files.
+ Move PCI_INVALID_VENDORDEVICEID definitions from various C files
to cpukit pci.h
Some register layout definitions for LEON3 reside in ambapp.h which
does not really has anything to do with device registers. The
register structures has been incorrectly named LEON3_*, the cores
are not only used on LEON3 but on LEON4 and perhaps on LEON5 when
that day comes. Some structures has been renamed according to the
GRLIB core name instead, which CPU that actually use it is not
relevant. Drivers has been updated with the new names.
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
for details.
The drivers are updated to use the new AMBA layer, however the
backwards-compatibility interface (ambapp_old) is used.
The old layer had some limitations/problems for multiple AHB
buses since the data structure containing all AMBA devices
were allocated before scanning.
The new layer create devices as they are found and memory is
allocated using malloc() or bsp_early_malloc() during booting.
The old 8 functions for finding a specific AHB-Slave or
APB-Slave device has been replaced with one function,
ambapp_for_each(), which iterates over all devices matching
the specified search options and calls a user provided
function. The new way lowers the footprint and makes searching
more flexible.
The frequency information is now supported, if the frequency
of one device is reported by the user.
More AHB-to-AHB bridges are supported.
The API has been split into several parts in order to lower the
footprint.
The API also introduces the AMBAPP CORE concept, where one
ambapp_core can be created from one AHB Master, AHB Slave
and one APB Slave, at least one device is required for creating
a core.
The implementation use IRQ number instead of vector number since
some IRQs does not have a unique vector, for example the extended
interrupts all enter the same trap vector entry.
Added support for the LEON3 extended interrupt controller when using
the shared IRQ layer.
ERC32 patches untested.
Regenerate
If bsp_early_malloc() is called early during boot room will be
allocated after BSS END. If the function is called after boot
is will call malloc() instead. The returned memory is not freeable
and always 8-byte aligned.
If the bsp_early_malloc() isn't called the function is not
dragged in and the workspace will be unmodified in size.
When data cache snooping is not present the cache needs
flushing, the SPARC LEON CPUs does not have to ability
to flush individual cache rows and flushing all cache is
expensive. Instead the LDA instruction is used to force
cache miss on individual loads during the IP-align copy
operation required anyway.
GRETH GBIT non-snooping systems are still unsupported,
since it use zero-copy (can deal with unaligned DMA).
Let the bsp.h select if the GRETH driver is supported.
Currently only the LEON2/LEON3 platforms BSPs builds the
driver.
Moved the intelligence whether the driver is supported or not
completely to the BSP, now that bsp.h is included (even though it
is a driver... hmm). The ERC32 was never supported, so HAS_SMC91111
is not added to erc32/include/bsp.h.
The low level routines can be used in different occasions, it will be
required when accessing PCI.
Note the difference between byteorder.h (inlined functions) and access.S
where the functions will be declared in the library archive librtemscpu.a.
Function names starting with _ are in library and can be referenced by
function pointers.
PR 1766/bsps
* clock/ckinit.c: Add missing read of Timer_Counter_1.
* Makefile.am: Fix broken path to clockdrv_shell.h.
* Makefile.am, configure.ac: runtest for this BSP obsoleted by
rtems-testing/sim-scripts support. Please use those scripts.
* tools/.cvsignore, tools/ChangeLog, tools/Makefile.am,
tools/configure.ac, tools/runtest.in: Removed.
