Update #2502.
Notepads where a feature of RTEMS' tasks that simply functioned in
the same way as POSIX keys or threaded local storage (TLS). They were
introduced well before per task variables, which are also deprecated,
and were barely used in favor of their POSIX alternatives.
In addition to their scarce usage, Notepads took up unnecessary memory.
For each task:
- 16 32-bit integers were allocated.
- A total of 64 bytes per task per thread.
This is especially critical in low memory and safety-critical applications.
They are also defined as uint32_t, and therefore are not guaranteed to
hold a pointer.
Lastly, they are not portable solutions for SMP and uniprocessor systems,
like POSIX keys and TLS.
updates #2493.
Update #2408.
Call bsp_work_area_initialize() before bsp_start(). This allows
bsp_start() to use malloc() etc. which is beneficial for systems with a
plug-and-play hardware enumeration.
Update #2408.
Move content to bsp_predriver_hook() functions of the BSPs.
Update #2408.
do
echo $b
# echo $g
-i $b
done
Update #2271.
Before the LIBPCI didn't probe device0 (AD16), the host bridge
drivers used bus=dev=func=0 to internally probe the host bridge's
target interface. Now that LIBPCI uses bus=dev=func=0 to access
device0, bus=0xff is introduced internally to identify the
host bridge target configuration space.
Interrupts have not been test yet
Most drivers use the Driver Manager for device probing, they
work on AMBA-over-PCI systems if PCI is big-endian.
New APIs:
* GPIO Library, interfaced to GRGPIO
* GENIRQ, Generic interrupt service implementation helper
New GRLIB Drivers:
* ACTEL 1553 RT, user interface is similar to 1553 BRM driver
* GR1553 (1553 BC, RT and BM core)
* AHBSTAT (AHB error status core)
* GRADCDAC (Core interfacing to ADC/DAC hardware)
* GRGPIO (GPIO port accessed from GPIO Library)
* MCTRL (Memory controller settings configuration)
* GRETH (10/100/1000 Ethernet driver using Driver manager)
* GRPWM (Pulse Width Modulation core)
* SPICTRL (SPI master interface)
* GRSPW_ROUTER (SpaceWire Router AMBA configuration interface)
* GRCTM (SpaceCraft on-board Time Management core)
* SPWCUC (Time distribution over SpaceWire)
* GRTC (SpaceCraft up-link Tele core)
* GRTM (SpaceCraft down-link Tele Metry core)
GR712RC ASIC specific interfaces:
* GRASCS
* CANMUX (select between OCCAN and SATCAN)
* SATCAN
* SLINK
The CCHIP driver is replaced with the GR_701 driver. The
RASTA driver is replaced by the GR-RASTA-IO driver.
All drivers are now compatible with both LEON2 and LEON3,
drivers were initialized directly by the PCI-board drivers
are now initialized by the driver manager and therefore
does not require the double code created by including for
example grcan.c into grcan_rasta.c. The other drivers needs
to be updated to the driver manager framework however.
Added support for:
* GR-701 (only LEON2 before)
* GR-RASTA-IO (only LEON2 before)
* GR-RASTA-ADCDAC
* GR-RASTA-TMTC
* GR-RASTA-SPW-ROUTER
* GR-TMTC-1553
In some non-standard designs GRLIB peripherals are used together
LEON2. This patch adds a GRLIB amba Plug&Play driver so that AMBA
devices can be found from Plug&Play the same way as with the LEON3
BSP.
The user is required to add an AMBA-PnP device entry into the LEON2
bus configuration, so that the driver manager unite this driver
with the "fake" device and start scanning after AMBA PnP devices.
The old code used a limited PCI configuration library, which was
duplicated into LEON2 and LEON3 BSP pci.c together with respective
Host controller PCI interface.
The LEON2 BSP had support for AT697 PCI, and LEON3 for GRPCI PCI
Host controller. With this update new PCI Host drivers are added,
and all support the new generic PCI Library:
* AT697 PCI (LEON2 only)
* GRPCI (LEON2-GRLIB and LEON3)
* GRPCI2 (LEON2-GRLIB and LEON3)
* Actel PCIF GRLIB Wrapper (LEON3 only)
The LEON2 BSP is defined as big-endian PCI in bsp.h, since the
AT697 supports only big-endian PCI.
With this patch the LEON family can access the GRLIB GPTIMER using
the Timer library (TLIB).
A System Clock driver instead of BSP/clock/ck_init.c is provided
using the TLIB. The classic clock driver is split in two parts,
clock driver and timer driver. The BSPs need only to fullfill the
timer interface instead of the clock interface. Currently only
LEON3 uses it. The LEON2 Timer is not ported to TLIB.
The GPTIMER driver is implemented using the Driver Manager, so the
System Clock Driver is at this point only suitable for LEON3 when
the driver manager is initialized during BSP startup. When the DrvMgr
is not initialized during startup the standard BSP/clock dirver is
used.
LEON2 sometimes also needs to access GPTIMER when a off-chip GRLIB AMBA
systems is connected, for example AMBA-over-PCI.
This allows it to be wrapped by another function at link-time
and can be used to trace interrupts. If not placed in a separate
file, the function pointer address used in BSP_shared_interrupt_init
will be resolved at compile-time, and the function will not be wrappable.
Fixes bug introduced with dff1803cfbec3775fff1b9c34cc707c05494dc3b.
The dummy.c was a de-facto default configuration. Rename it to
default-configuration.c. Use unlimited objects and the stack checker.
This makes it easier for new RTEMS users which will likely use this file
if they just work with the usual main() function as the application
entry point. Provide proper arguments for main() using the BSP command
line. Add spare user extensions and drivers.
Do not initialize the network by default. Delete bspinit.c.
Condition needs to be inverted, as a 1 in the mask register means
that the interrupt is enabled. Solves ticket #1959 in trac.
close #2113
The LEON2 and ERC32 maps the new macros to CPU0 since they do not
support SMP. With the LEON3 a specific CPU's interrupt controller
registers can be modified using macros.
Now that a SPARC fatal handler is defined, we no longer
need the BSP specific reset routine.
The Fatal_halt handler now have two options, either halt
as before or enter system error state to return to
debugger or simulator. The exit-code is now also
propagated to the debugger which is very useful for
testing.
The CPU_Fatal_halt handler was split up into two, since
the only the LEON3 support the CPU power down.
The LEON3 halt now uses the power-down instruction to save
CPU power. This doesn't stop a potential watch-dog timer
from expiring.
Instead of calling the system call TA instruction directly it
is better paractise to isolate the trap implementation to the
system call functions.
BSP_fatal_exit() is added.
output.
Rename _BSP_Exception_frame_print() to _CPU_Exception_frame_print() to
be in line with other CPU port functions.
not updated.
