* | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-16 | 1 | -3/+3 |
| | | | | | | | | | | | | Makefile.am: Reflect having moved automake. clock/Makefile.am: Reflect having moved automake. console/Makefile.am: Reflect having moved automake. gnatsupp/Makefile.am: Reflect having moved automake. include/Makefile.am: Reflect having moved automake. start/Makefile.am: Reflect having moved automake. startup/Makefile.am: Reflect having moved automake. timer/Makefile.am: Reflect having moved automake. wrapup/Makefile.am: Reflect having moved automake. | ||||
* | 2002-12-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-10 | 1 | -1/+0 |
| | | | | * wrapup/Makefile.am: Don't include @RTEMS_BSP@.cfg. | ||||
* | 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-08-11 | 1 | -2/+2 |
| | | | | | * start/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o. | ||||
* | 2002-07-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-07-04 | 1 | -1/+1 |
| | | | | | * wrapup/Makefile.am: Eliminate TMPINSTALL_FILES. Remove $(OBJS) from all-local. | ||||
* | 2002-06-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-06-30 | 1 | -8/+0 |
| | | | | * wrapup/Makefile.am: Remove preinstallation of libbsp.a, | ||||
* | 2002-04-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-04-03 | 1 | -1/+1 |
| | | | | | | * configure.ac: Remove BSPOPTS_*(NO_TABLE_MOVE). Remove BSPOPTS_*(FPU_REVB). * wrapup/Makefile.am: Remove tbr. | ||||
* | 2002-03-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-29 | 1 | -1/+1 |
| | | | | | | * configure.ac: Add BSPOPTS_*(NO_TABLE_MOVE). Add BSPOPTS_*(FPU_REVB). * wrapup/Makefile.am: Add tbr. | ||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 1 | -1/+0 |
| | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * clock/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * console/Makefile.am: Remove AUTOMAKE_OPTIONS. * gnatsupp/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * start/Makefile.am: Remove AUTOMAKE_OPTIONS. * startup/Makefile.am: Remove AUTOMAKE_OPTIONS. * timer/Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS. | ||||
* | 2002-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-01-06 | 1 | -4/+0 |
| | | | | | * configure.ac: Remove NETWORKING support. * wrapup/Makefile.am: Remove NETWORKING support. | ||||
* | 2000-11-14 Jiri Gaisler <jgais@ws.estec.esa.nl> | Joel Sherrill | 2000-11-15 | 1 | -2/+2 |
| | | | | | * wrapup/Makefile.am: Pick up cache code from libcpu and pick up .o's instead of .rel's from libcpu. | ||||
* | 2000-11-13 Jiri Gaisler <jgais@ws.estec.esa.nl> | Joel Sherrill | 2000-11-13 | 2 | -0/+42 |
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.in, times, clock/.cvsignore, clock/Makefile.am, clock/ckinit.c, console/.cvsignore, console/Makefile.am, console/console.c, console/consolereserveresources.c, console/debugputs.c, gnatsupp/.cvsignore, gnatsupp/Makefile.am, gnatsupp/gnatsupp.c, include/.cvsignore, include/Makefile.am, include/bsp.h, include/coverhd.h, include/leon.h, start/.cvsignore, start/Makefile.am, startup/.cvsignore, startup/Makefile.am, startup/boardinit.S, startup/linkcmds, startup/setvec.c, startup/spurious.c, timer/.cvsignore, timer/Makefile.am, timer/timer.c, tools/.cvsignore, tools/Makefile.am, tools/configure.in, tools/runtest.in, wrapup/.cvsignore, wrapup/Makefile.am: New file. |
