* startup/boardinit.S: Include <rtems/asm.h> instead of <asm.h>.
* console/console.c: Include <rtems/ringbuf.h> instead of <ringbuf.h>.
* clock/ckinit.c, console/console.c, console/debugputs.c,
include/bsp.h, include/leon.h, startup/setvec.c, startup/spurious.c,
timer/timer.c: Convert to using c99 fixed size types.
* Makefile.am: Merge-in clock/Makefile.am, leon_open_eth/Makefile.am,
startup/Makefile.am, console/Makefile.am, gnatsupp/Makefile.am,
timer/Makefile.am, wrapup/Makefile.am.
Use automake compilation rules.
* clock/Makefile.am, leon_open_eth/Makefile.am, startup/Makefile.am,
console/Makefile.am, gnatsupp/Makefile.am, timer/Makefile.am,
wrapup/Makefile.am: Remove.
* Makefile.am: Add dirstamp support to preinstallation.
* gnatsupp/Makefile.am: Cosmetics.
* leon_open_eth/Makefile.am: Correct paths to automake/*.am..
PR 538/bsps:
* wrapup/Makefile.am: Add leon_open_eth.rel
* gnatsupp/Makefile.am: Remove all-local: $(ARCH).
* leon_open_eth/Makefile.am: Remove all-local: $(ARCH).
* clock/ckinit.c, console/console.c, console/consolereserveresources.c,
console/debugputs.c, include/bsp.h, include/coverhd.h,
include/leon.h, startup/setvec.c, timer/timer.c: URL for license
changed.
PR 477/networking
* Makefile.am, configure.ac, console/console.c, include/bsp.h,
startup/setvec.c, wrapup/Makefile.am: Add network support and enable
custom power down.
* leon_open_eth/.cvsignore, leon_open_eth/Makefile.am,
leon_open_eth/leon_open_eth.c: New files.
gnatsupp/Makefile.am: Reflect having moved automake.
* gnatsupp/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* gnatsupp/Makefile.am: Use .$(OBJEXT) instead of .o.
* gnatsupp/Makefile.am: Remove AUTOMAKE_OPTIONS.
* clock/ckinit.c, console/console.c, include/bsp.h, include/leon.h,
startup/setvec.c, timer/timer.c: Fixed typo.
* console/debugputs.c: Switched to unsigned characters.
* console/console.c: Removed console_reserve_resources().
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs,
configure.in, times, clock/.cvsignore, clock/Makefile.am,
clock/ckinit.c, console/.cvsignore, console/Makefile.am,
console/debugputs.c, gnatsupp/.cvsignore,
gnatsupp/Makefile.am, gnatsupp/gnatsupp.c,
include/coverhd.h, include/leon.h, start/.cvsignore,
start/Makefile.am, startup/.cvsignore, startup/Makefile.am,
startup/boardinit.S, startup/linkcmds, startup/setvec.c,
startup/spurious.c, timer/.cvsignore, timer/Makefile.am,
timer/timer.c, tools/.cvsignore, tools/Makefile.am,
tools/configure.in, tools/runtest.in, wrapup/.cvsignore,
wrapup/Makefile.am: New file.
