subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
properly reflect the const on the buffer pointer being passed in.
be resolved.
defined in the targopts.h file.
hardware. From Jiri Gaisler <jgais@wd.estec.esa.nl>. Supports sis
2.6 and later.
