PR 1917/bsps
* Makefile.am, console/erc32_console.c: Modifications to add dynamic
tables for libchip serial drivers.
PR 1750/bsps
* console/erc32_console.c, make/custom/erc32.cfg: The new console
driver did not support polled mode. It also had a bug in which it
could lose a transmitter interrupt.
* console/erc32_console.c: Add polled support. Tinker with interrupt
handler to not dequeue characters unless TX is empty.
PR 1506/bsps
* console/console.c: Removed.
* console/erc32_console.c: New file. Use shared console driver.
Make sure interrupt support works. PPPD confirmed on sis.
Reflect changes to rtems_termios_callbacks->write.
* console/console.c: Fix warning.
* console/console.c: Spacing.
* Makefile.am: Remove all references to console_reserve_resources and
termios_reserve_resources.
* console/consolereserveresources.c: Removed.
* console/debugputs.c, include/bsp.h, startup/spurious.c: Remove debug
print methods that are redundant with prntk and replace their use
with printk.
PR 1233/bsps
* Makefile.am, console/console.c, console/debugputs.c: Move printk
support code into debug IO file so you do not get the entire console
driver when you do not want it.
* clock/ckinit.c, console/console.c: Use common clock driver template
and eliminate all fast idle code specific to this BSP. This
eliminates a fair amount of code in the BSP clock driver and
bsp_startup. The LEON3 has to do a scan of the AMBA bus to find the
timer so I added the new hook Clock_driver_support_find_timer to
support this. In general, there was some clean up to the file headers
of various files.
PR 1100/bsps
* console/debugputs.c: Remove redundant return.
* startup/boardinit.S: Include <rtems/asm.h> instead of <asm.h>.
* console/console.c: Include <rtems/ringbuf.h> instead of <ringbuf.h>.
* clock/ckinit.c, console/console.c, console/debugputs.c,
erc32sonic/erc32sonic.c, include/bsp.h, include/erc32.h,
startup/setvec.c, startup/spurious.c, timer/timer.c: Convert to
using c99 fixed size types.
* Makefile.am: Merge-in clock/Makefile.am, erc32sonic/Makefile.am,
startup/Makefile.am, console/Makefile.am, gnatsupp/Makefile.am,
timer/Makefile.am, wrapup/Makefile.am.
Use automake compilation rules.
* clock/Makefile.am, erc32sonic/Makefile.am, startup/Makefile.am,
console/Makefile.am, gnatsupp/Makefile.am, timer/Makefile.am,
wrapup/Makefile.am: Remove.
* Makefile.am: Add dirstamp support to preinstallation.
* erc32sonic/Makefile.am: Cosmetics.
* gnatsupp/Makefile.am: Cosmetics.
* start/Makefile.am: Cosmetics.
* erc32sonic/Makefile.am: Remove all-local: $(ARCH).
* gnatsupp/Makefile.am: Remove all-local: $(ARCH).
* clock/ckinit.c, console/console.c, console/consolereserveresources.c,
console/debugputs.c, include/bsp.h, include/coverhd.h,
include/erc32.h, startup/erc32mec.c, startup/setvec.c, timer/timer.c:
URL for license changed.
erc32sonic/Makefile.am: Reflect having moved automake.
gnatsupp/Makefile.am: Reflect having moved automake.
* erc32sonic/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* gnatsupp/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* erc32sonic/Makefile.am: Use .$(OBJEXT) instead of .o.
* gnatsupp/Makefile.am: Use .$(OBJEXT) instead of .o.
* erc32sonic/Makefile.am: Remove AUTOMAKE_OPTIONS.
* gnatsupp/Makefile.am: Remove AUTOMAKE_OPTIONS.
* console/debugputs.c: Switched to unsigned characters.
* clock/Makefile.am, console/Makefile.am, gnatsupp/Makefile.am,
converted to automake.
that converts the sparc directory to automake.
Ralf's note: The implementation of libbsp/sparc/* gives a nearly minimal
example of the new configuration scheme.
dependencies of "Makefile".
--enable-maintainer-mode.
reduce dependencies and shrink minimum executable size.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
"if defined".
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
