* | 2003-08-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-06 | 1 | -3/+0 |
| | | | | | * bsp_specs: Remove -D__embedded__ -Asystem(embedded) from cpp. Remove cpp, old_cpp (now unused). | ||||
* | 2002-08-21 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-08-21 | 1 | -4/+4 |
| | | | | * bsp_specs: Added support for -nostdlibs. | ||||
* | 2001-12-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-01-04 | 1 | -1/+1 |
| | | | | | * bsp_specs: Replace -lrtemsall with -lrtemsbsp -lrtemscpu, replace -lrtemsall_g with -lrtemsbsp_g -lrtemscpu_g. | ||||
* | Moved startsis to start. | Joel Sherrill | 1999-11-19 | 1 | -2/+2 |
* | Now supports C++ global constructors and exceptions. | Joel Sherrill | 1999-08-05 | 1 | -2/+5 |
* | Incorporated Ralf Corsepius' idea for new -q flags to properly support | Joel Sherrill | 1998-02-11 | 1 | -2/+7 |
| | | | | "gmake debug". | ||||
* | Moved -qnolinkcmds option so arguments passed on the command line are | Joel Sherrill | 1997-12-20 | 1 | -2/+2 |
| | | | | | | | | | | | | | | | | | | | | | interpreted at the right point per Eric Norum's discovery: The problem with the my previous `fix' for adding linker commands was with the ordering of the options to the linker. For example, to make a larger heap size, the application Makefile would CFLAGS_LD = -Wl,--defsym -Wl,HeapSize=0x40000 The command passed to the linker would be : m68k-rtems-ld .... -T xxx/linkcmds .... --defsym HeapSize=0x40000 ..... This doesn't work because the script in linkcmds inserts a default value for HeapSize if HeapSize is not defined by the time the linker looks at the linkcmds script. The solution seems to be to move the -T linkcmds%s in the bsp_specs file out of the link specfication and into the lib specification -- a little unorthodox, perhaps, but it seems to work! | ||||
* | Modified bsp_specs per Eric Norum's suggestion to handle -qnolinkcmds | Joel Sherrill | 1997-12-19 | 1 | -1/+1 |
| | | | | switch which lets the user specify a different linker script. | ||||
* | Modified to search RTEMS library before Newlib C library. | Joel Sherrill | 1997-10-08 | 1 | -1/+1 |
* | Switched to new style which does not require hackspecs.awk. | Joel Sherrill | 1997-08-28 | 1 | -29/+13 |
* | new file used by gcc 2.8.x -specs option | Joel Sherrill | 1997-01-28 | 1 | -0/+34 |
