PR 1917/bsps
* Makefile.am, console/erc32_console.c: Modifications to add dynamic
tables for libchip serial drivers.
* Makefile.am: Fix broken path to clockdrv_shell.h.
* startup/bspdelay.c: Fix broken CVS-Id.
* Makefile.am, configure.ac: runtest for this BSP obsoleted by
rtems-testing/sim-scripts support. Please use those scripts.
* tools/.cvsignore, tools/ChangeLog, tools/Makefile.am,
tools/configure.ac, tools/runtest.in: Removed.
PR 1783/bsps
* include/bsp.h: Remove dead prototypes of Clock_delay() and delay().
Neither had bodies.
PR 1729/cpukit
* Makefile.am, configure.ac: Add next step in SMP support. This adds an
allocated array of the Per_CPU structures to support multiple cpus vs
a single instance of the structure which is still used if SMP support
is disabled. Configuration support is also added to explicitly enable
or disable SMP. But SMP can only be enabled for the CPUs which will
support it initially -- SPARC and i386. With the stub BSP support, a
BSP can be run as a single core SMP system from an RTEMS data
structure standpoint.
PR 1748/bsps
* clock/ckinit.c: When the clock tick generates an interrupt WHILE we
have interrupts disabled doing a get TOD or uptime, the get
nanoseconds handler was returning a bogusly large number.
PR 1750/bsps
* console/erc32_console.c, make/custom/erc32.cfg: The new console
driver did not support polled mode. It also had a bug in which it
could lose a transmitter interrupt.
* console/erc32_console.c: Add polled support. Tinker with interrupt
handler to not dequeue characters unless TX is empty.
* include/tm27.h, startup/spurious.c:
* timer/timer.c: Include <rtems/btimer.h>.
* make/custom/erc32.cfg: Remove -ftest-coverage.
* bsp_specs: Revert accidental commit.
* bsp_specs, make/custom/erc32.cfg: Fix typo where license said
found in found in.
* Makefile.am: Add bspinit.c from the shared BSP files.
* configure.ac: Remove AC_CHECK_SIZEOF([void *]).
* configure.ac: Added AC_CHECK_SIZEOF macro.
* startup/linkcmds: Include basic linker command file and define only
board specific values. Define RAM and PROM limits only if not defined
by command line arguments.
* Makefile.am, preinstall.am: Reflect changes above.
PR 1506/bsps
* console/console.c: Removed.
* console/erc32_console.c: New file. Use shared console driver.
Make sure interrupt support works. PPPD confirmed on sis.
Reflect changes to rtems_termios_callbacks->write.
* Makefile.am: Switch to ../../shared/bspstart.c
* make/custom/erc32.cfg: Remove RTEMS_BSP_FAMILY.
* console/console.c: Fix warning.
* make/custom/erc32.cfg: New (relocated from /make/custom).
* make/custom/sis.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* console/console.c: Spacing.
* Makefile.am, include/bsp.h, startup/setvec.c: Split idle method into
its own file. Properly note to confdefs.h that this BSP has its own
idle thread.
* startup/bspidle.c: New file.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
PR 1391/bsps
* startup/spurious.c: Format was %d but had leading 0x.
PR 1390/bsps
* startup/linkcmds: Fix sections so C++ global constructors and
destructors work with late model (>= 4.3) gcc versions.
* startup/setvec.c: Change prototype of IDLE thread to consistently
return void * and take a uintptr_t argument.
* bsp_specs: Remove -e start from %link.
* include/coverhd.h: Removed.
* clock/ckinit.c: include "../../../shared/clockdrv_shell.h".
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
* Makefile.am: bsp_cleanup() had the same code which was executed when
you returned from boot_card() to start.S. So just use the stub
bsp_cleanup() implementation and remove a file.
* include/bsp.h: Remove unnecessary boilerplate comments.
* startup/linkcmds: Add start symbol to eliminate warning.
* startup/linkcmds: Work Area should start on 16 byte boundary.
* Makefile.am: Use shared bsp_get_work_area() in its own file and rely
on BSP Framework to perform more initialization.
* include/bsp.h: Review of all bsp_cleanup() implementations. In this
phase, all prototypes were removed from bsp.h and empty
implementations were removed and made to use the shared stub.
* console/console.c, timer/timer.c: Convert to "bool".
* timer/timer.c: Convert using "bool".
