Some register layout definitions for LEON3 reside in ambapp.h which
does not really has anything to do with device registers. The
register structures has been incorrectly named LEON3_*, the cores
are not only used on LEON3 but on LEON4 and perhaps on LEON5 when
that day comes. Some structures has been renamed according to the
GRLIB core name instead, which CPU that actually use it is not
relevant. Drivers has been updated with the new names.
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
for details.
The old layer had some limitations/problems for multiple AHB
buses since the data structure containing all AMBA devices
were allocated before scanning.
The new layer create devices as they are found and memory is
allocated using malloc() or bsp_early_malloc() during booting.
The old 8 functions for finding a specific AHB-Slave or
APB-Slave device has been replaced with one function,
ambapp_for_each(), which iterates over all devices matching
the specified search options and calls a user provided
function. The new way lowers the footprint and makes searching
more flexible.
The frequency information is now supported, if the frequency
of one device is reported by the user.
More AHB-to-AHB bridges are supported.
The API has been split into several parts in order to lower the
footprint.
The API also introduces the AMBAPP CORE concept, where one
ambapp_core can be created from one AHB Master, AHB Slave
and one APB Slave, at least one device is required for creating
a core.
The implementation use IRQ number instead of vector number since
some IRQs does not have a unique vector, for example the extended
interrupts all enter the same trap vector entry.
Added support for the LEON3 extended interrupt controller when using
the shared IRQ layer.
ERC32 patches untested.
Regenerate
* Makefile.am: Remove references to non-existing files.
* Makefile.am, shared/can/occan.c, shared/include/ambapp.h: Add initial
i2c and update OC-CAN support.
* shared/i2c/i2cmst.c, shared/include/i2cmst.h: New files.
* Makefile.am: Add the following new drivers: PCI, b1553BRM,
SpaceWire(GRSPW), CAN (GRCAN,OC_CAN), Raw UART.
* shared/include/apbuart.h, shared/include/apbuart_pci.h,
shared/include/apbuart_rasta.h, shared/include/b1553brm.h,
shared/include/b1553brm_pci.h, shared/include/b1553brm_rasta.h,
shared/include/debug_defs.h, shared/include/grcan.h,
shared/include/grcan_rasta.h, shared/include/grcan_spwrtc.h,
shared/include/grspw.h, shared/include/grspw_pci.h,
shared/include/grspw_rasta.h, shared/include/occan.h,
shared/include/occan_pci.h, shared/include/pci.h: New files.
* Makefile.am: LEON3 AMBA PnP bus scanning moved to shared/amba/amba.c
and shared/include/ambapp.h. The AMBA scanning was improved to take
account for PnP info address translation. This is useful when
scanning remote AMBA busses for example when a board connected with
PCI has an AMBA bus that needs to be scanned, before the addresses
was hard coded. Also, LEON2 now have AMBA PnP bus scanning support.
By using the new AMBA scanning routines it is possible to isolate the
AMBA scanning code to ambapp.c, however existing drivers should be
updated to use them in order to save space.
* Makefile.am: Merge-in shared/Makefile.am.
* ChangeLog: Merge-in shared/ChangeLog.
* configure.ac: Remove shared/Makefile.am.
* Makefile.am: Use @RTEMS_BSP_FAMILY@ instead of
$(RTEMS_BSP_FAMILY).
* Makefile.am, configure.in: Added shared directory as part
of enhancing ERC32 and adding LEON.
that converts the sparc directory to automake.
Ralf's note: The implementation of libbsp/sparc/* gives a nearly minimal
example of the new configuration scheme.
