path: root/c/src/lib/libbsp/sparc/ChangeLog (follow)
* 2008-09-23 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-09-231-0/+4
| | | | * shared/bspclean.c: Removed.
* 2008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-09-161-0/+5
| | | | | * shared/bspstart.c: Remove unnecessary includes of rtems/libcsupport.h and rtems/libio.h.
* 2008-09-15 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-09-151-0/+6
| | | | | | * shared/bspstart.c: Use shared bsp_get_work_area() in its own file and rely on BSP Framework to perform more initialization. * shared/bspgetworkarea.c: New file.
* 2008-08-18 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2008-08-181-0/+4
| | | | * shared/bspstart.c: Remove bogus local declaration.
* Changed bsp_get_workarea() to bsp_get_work_area() andThomas Doerfler2008-07-241-0/+6
| | | | added support for an optional separate heap area.
* 2008-05-15 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-05-151-0/+14
| | | | | | | | | | | | | | * shared/bspstart.c, shared/start.S: Add capability for bootcard.c BSP Initialization Framework to ask the BSP where it has memory for the RTEMS Workspace and C Program Heap. These collectively are referred to as work area. If the BSP supports this, then it does not have to include code to split the available memory between the two areas. This reduces the amount of code in the BSP specific bspstart.c file. Additionally, the shared framework can initialize the C Library, call rtems_debug_enable(), and dirty the work area memory. Until most/all BSPs support this new capability, if the BSP supports this, it should call RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION from its configure.ac. When the transition is complete, this autoconf macro can be removed.
* 2008-05-12 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-05-121-0/+12
| | | | | | | | | | | | * shared/bspstart.c: Refactored and renamed initialization routines to rtems_initialize_data_structures, rtems_initialize_before_drivers, rtems_initialize_device_drivers, and rtems_initialize_start_multitasking. This opened the sequence up so that bootcard() could provide a more robust and flexible framework which is easier to explain and understand. This also lays the groundwork for sharing the division of available memory between the RTEMS workspace and heap and the C library initialization across all BSPs.
* 2008-05-06 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-05-061-0/+4
| | | | * shared/start.S: Spacing.
* 2007-12-11 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-12-111-0/+5
| | | | | * shared/bspstart.c: Eliminate copies of the Configuration Table. Use the RTEMS provided accessor macros to obtain configuration fields.
* 2007-12-06 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-12-061-0/+4
| | | | * shared/include/grcan_spwrtc.h: Removed.
* 2007-12-05 Daniel Hellstrom <daniel@gaisler.com>Joel Sherrill2007-12-051-0/+4
| | | | * shared/include/ambapp.h: Sync head and 4.8 branch.
* 2007-12-04 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-12-041-0/+6
| | | | | | * shared/bspstart.c: Move interrupt_stack_size field from CPU Table to Configuration Table. Eliminate CPU Table from all ports. Delete references to CPU Table in all forms.
* 2007-12-03 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-12-031-0/+9
| | | | | | | | | * shared/bspstart.c: Moved most of the remaining CPU Table fields to the Configuration Table. This included pretasking_hook, predriver_hook, postdriver_hook, idle_task, do_zero_of_workspace, extra_mpci_receive_server_stack, stack_allocate_hook, and stack_free_hook. As a side-effect of this effort some multiprocessing code was made conditional and some style clean up occurred.
* 2007-11-30 Daniel Hellstrom <daniel@gaisler.com>Joel Sherrill2007-11-301-0/+6
| | | | | | * shared/include/grspw.h, shared/spw/grspw.c: GRSPW SpaceWire Driver. Fixes typecast to volatile integer instead of to integer. Added scanning for GRSPW2 Core, The GRSPW2 core is run in legacy mode.
* 2007-11-30 Daniel Hellstrom <daniel@gaisler.com>Joel Sherrill2007-11-301-0/+7
| | | | | | | * shared/can/occan.c: LEON2/3 OCCAN CAN driver. Fixes typecast to volatile integer where needed. Fixes bug where closing the driver and opening it again could make the driver not starting transmission due to the software fifo was not cleared.
* 2007-11-30 Daniel Hellstrom <daniel@gaisler.com>Joel Sherrill2007-11-301-0/+9
| | | | | | | | | * shared/can/grcan.c, shared/can/grcan_rasta.c, shared/include/ambapp.h: GRCAN CAN driver. Fixes Interrupt enabling/disabling in the driver, interrupt may not be restored correctly. Implements the baud rate calculation routine. Removed unnecessary printk. Fixed scanning to support GRCAN and GRHCAN hardware. Added GRCAN device number to ambapp.h.
* 2007-10-11 Daniel Hellstrom <daniel@gaisler.com>Joel Sherrill2007-10-111-0/+6
| | | | | | * Makefile.am, shared/can/occan.c, shared/include/ambapp.h: Add initial i2c and update OC-CAN support. * shared/i2c/i2cmst.c, shared/include/i2cmst.h: New files.
* 2007-09-21 Daniel Hellstrom <daniel@gaisler.com>Joel Sherrill2007-09-211-0/+4
| | | | * shared/can/occan.c: Fix warning on Diab compiler.
* 2007-09-19 Daniel Hellstrom <daniel@gaisler.com>Joel Sherrill2007-09-191-0/+4
| | | | * shared/can/occan.c: Fix Reenable command and fix typo.
* 2007-09-18 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-09-181-0/+4
| | | | * shared/1553/b1553brm.c, shared/can/grcan.c: Remove include of sched.h
* 2007-09-13 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-09-131-0/+5
| | | | | * shared/spw/grspw.c: Remove include of sched.h. It does not appear to be needed and is unavailable when POSIX is disabled.
* 2007-09-12 Daniel Hellstrom <daniel@gaisler.com>Joel Sherrill2007-09-121-0/+5
| | | | | * shared/can/grcan.c, shared/include/debug_defs.h, shared/spw/grspw.c: Remove use of DEBUG_printf.
* 2007-09-07 Daniel Hellstrom <daniel@gaisler.com>Joel Sherrill2007-09-071-0/+6
| | | | | | * shared/1553/b1553brm.c, shared/can/grcan.c, shared/can/grcan_rasta.c, shared/can/occan.c, shared/spw/grspw.c, shared/spw/grspw_pci.c, shared/uart/apbuart.c: Remove warnings.
* 2007-09-06 Daniel Hellstrom <daniel@gaisler.com>Joel Sherrill2007-09-061-0/+4
| | | | * shared/pci/pcifinddevice.c: New file.
* 2007-09-06 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-09-061-0/+4
| | | | * shared/uart/apbuart.c: Fix some warnings.
* 2007-09-06 Daniel Hellstrom <daniel@gaisler.com>Joel Sherrill2007-09-061-0/+11
| | | | | | | | | | | New drivers: PCI, b1553BRM, SpaceWire(GRSPW), CAN (GRCAN,OC_CAN), Raw UART. * shared/1553/b1553brm.c, shared/1553/b1553brm_pci.c, shared/1553/b1553brm_rasta.c, shared/can/grcan.c, shared/can/grcan_rasta.c, shared/can/occan.c, shared/can/occan_pci.c, shared/spw/grspw.c, shared/spw/grspw_pci.c, shared/spw/grspw_rasta.c, shared/uart/apbuart.c, shared/uart/apbuart_pci.c, shared/uart/apbuart_rasta.c: New files missed in previous commit.
* 2007-09-06 Daniel Hellstrom <daniel@gaisler.com>Joel Sherrill2007-09-061-0/+14
| | | | | | | | | | | | | * Makefile.am: Add the following new drivers: PCI, b1553BRM, SpaceWire(GRSPW), CAN (GRCAN,OC_CAN), Raw UART. * shared/include/apbuart.h, shared/include/apbuart_pci.h, shared/include/apbuart_rasta.h, shared/include/b1553brm.h, shared/include/b1553brm_pci.h, shared/include/b1553brm_rasta.h, shared/include/debug_defs.h, shared/include/grcan.h, shared/include/grcan_rasta.h, shared/include/grcan_spwrtc.h, shared/include/grspw.h, shared/include/grspw_pci.h, shared/include/grspw_rasta.h, shared/include/occan.h, shared/include/occan_pci.h, shared/include/pci.h: New files.
* 2007-09-05 Daniel Hellstrom <daniel@gaisler.com>Joel Sherrill2007-09-061-0/+8
| | | | | | | | * shared/bspstart.c: LEON2 and LEON3 Data cache snooping detection on startup, for drivers. (LEON2,3 are configurable processors, they can be with or without DCache snooping. Caches without snooping needs the drivers to flush cache or use the sparc instruction lda to force cache miss...)
* 2007-09-05 Daniel Hellstrom <daniel@gaisler.com>Joel Sherrill2007-09-061-0/+4
| | | | * shared/amba/ambapp.c, shared/include/ambapp.h: New files.
* 2007-09-05 Daniel Hellstrom <daniel@gaisler.com>Joel Sherrill2007-09-061-0/+12
| | | | | | | | | | | | * Makefile.am: LEON3 AMBA PnP bus scanning moved to shared/amba/amba.c and shared/include/ambapp.h. The AMBA scanning was improved to take account for PnP info address translation. This is useful when scanning remote AMBA busses for example when a board connected with PCI has an AMBA bus that needs to be scanned, before the addresses was hard coded. Also, LEON2 now have AMBA PnP bus scanning support. By using the new AMBA scanning routines it is possible to isolate the AMBA scanning code to ambapp.c, however existing drivers should be updated to use them in order to save space.
* 2007-05-15 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2007-05-151-0/+4
| | | | * shared/bspstart.c: Add include <rtems/bspIo.h> to remove warning.
* 2007-05-09 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-05-091-0/+5
| | | | | * shared/bspstart.c, shared/gnatcommon.c: Remove debug print methods that are redundant with prntk and replace their use with printk.
* 2007-04-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2007-04-171-0/+5
| | | | | * erc32/tools/runtest.in, leon2/tools/runtest.in, leon3/tools/runtest.in: Do not run pppd.exe from batch mode script.
* 2007-03-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2007-03-111-0/+6
| | | | | | * shared/bspstart.c: Remove assignments of Cpu_table.do_zero_of_workspace to TRUE since TRUE is the default value in boot_card.c
* 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-12-021-0/+4
| | | | * configure.ac: New BUG-REPORT address.
* 2006-11-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-11-161-0/+10
| | | | | | | | | | * shared/bspstart.c, shared/start.S: Use common clock driver template and eliminate all fast idle code specific to this BSP. This eliminates a fair amount of code in the BSP clock driver and bsp_startup. The LEON3 has to do a scan of the AMBA bus to find the timer so I added the new hook Clock_driver_support_find_timer to support this. In general, there was some clean up to the file headers of various files.
* 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-10-171-0/+4
| | | | * configure.ac: Require autoconf-2.60. Require automake-1.10.
* 2006-01-10 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-01-101-0/+4
| | | | * shared/start.S: Add include of bspopts.h so SIS quirks will trigger.
* 2006-01-09 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2006-01-091-0/+4
| | | | * shared/start.S: Backport from rtems-4-6-branch.
* 2005-10-16 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-10-161-20/+62
| | | | | | * Makefile.am: Merge-in shared/Makefile.am. * ChangeLog: Merge-in shared/ChangeLog. * configure.ac: Remove shared/Makefile.am.
* 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-09-241-0/+4
| | | | * configure.ac: Require automake > 1.9.
* 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-121-0/+4
| | | | * acinclude.m4: Regenerate.
| | | | * configure.ac: RTEMS_CHECK_BSPDIR([$RTEMS_BSP_FAMILY]).
* 2004-01-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-131-0/+5
| | | | | * Makefile.am: Use @RTEMS_BSP_FAMILY@ instead of $(RTEMS_BSP_FAMILY).
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-121-0/+4
| | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59.
* 2003-10-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-201-0/+5
| | | | | * acinclude.m4: Reflect changes to bootstrap. * configure.ac: Remove RTEMS_CHECK_CUSTON_BSP.
* 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-181-0/+4
| | | | * Makefile.am: Reflect having moved aclocal/.
* Fix broken ChangeLog entries.Ralf Corsepius2003-08-181-1/+1
* 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-161-0/+4
| | | | Makefile.am: Reflect having moved automake.
* 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-111-0/+4
| | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address.
