* shmdr/addlq.c, shmdr/cnvpkt.c, shmdr/dump.c, shmdr/fatal.c,
shmdr/getlq.c, shmdr/getpkt.c, shmdr/init.c, shmdr/initlq.c,
shmdr/intr.c, shmdr/mpci.h, shmdr/mpisr.c, shmdr/poll.c,
shmdr/README, shmdr/receive.c, shmdr/retpkt.c, shmdr/send.c,
shmdr/setckvec.c, shmdr/shm_driver.h: Remove (Moved to
c/src/libchip/shmdr).
2003-12-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* bspstart.am: Use .$(OBJEXT) instead of .o.
* Makefile.am: Remove shmdr.
2003-12-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* bsp.am: Use $(mkdir_p) instead of $(mkinstalldirs).
2003-12-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* bsp.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
* Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g.
2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* Makefile.am: Use mkdir_p.
Remove dirs from PRE/TMPINSTALL_FILES.
* bsp.am: Replace bsplibdir by project_libdir.
Use mkdir_p instead of mkinstalldirs.
2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* bsp.am: Remove project_libdir.
* Makefile.am: Misc. fixes.
* bsp.am: Add project_libdir.
2003-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* bspstart.am: New.
2003-12-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* Makefile.am: Merge-in shared/Makefile.am, shmdr/Makefile.am.
* shared/Makefile.am: Remove.
* shmdir/Makefile.am: Remove.
* bsp.am: Add preinstallation dirstamp support.
2003-12-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* shmdr/Makefile.am: Remove all-local: $(ARCH).
2003-09-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* bsp.am: Reworked.
2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* Makefile.am: Reflect having moved automake/.
* shmdr/Makefile.am: Reflect having moved automake/.
2003-08-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* shmdr/Makefile.am: Reflect having merged configure.ac into
../../configure.ac.
* configure.ac: Remove (Merged into ../../configure.ac).
* Makefile.am: Reflect having merged configure.ac into
../../configure.ac.
2003-03-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* configure.ac: Remove AC_CONFIG_AUX_DIR.
2003-02-14 Joel Sherrill <joel@OARcorp.com>
AMD a29k port declared obsolete.
* a29k/.cvsignore, a29k/ChangeLog, a29k/Makefile.am, a29k/acinclude.m4,
a29k/configure.ac, a29k/portsw/.cvsignore, a29k/portsw/ChangeLog,
a29k/portsw/Makefile.am, a29k/portsw/README, a29k/portsw/bsp_specs,
a29k/portsw/configure.ac, a29k/portsw/times,
a29k/portsw/console/.cvsignore, a29k/portsw/console/Makefile.am,
a29k/portsw/console/concntl.h, a29k/portsw/console/console.c,
a29k/portsw/console/serial.c, a29k/portsw/console/serial.h,
a29k/portsw/include/.cvsignore, a29k/portsw/include/Makefile.am,
a29k/portsw/include/bsp.h, a29k/portsw/start/.cvsignore,
a29k/portsw/start/Makefile.am, a29k/portsw/start/amd.ah,
a29k/portsw/start/pswmacro.ah, a29k/portsw/start/register.S,
a29k/portsw/start/register.ah, a29k/portsw/start/start.S,
a29k/portsw/startup/.cvsignore, a29k/portsw/startup/Makefile.am,
a29k/portsw/startup/bspclean.c, a29k/portsw/startup/bspstart.c,
a29k/portsw/startup/linkcmds, a29k/portsw/startup/main.c,
a29k/portsw/startup/ramlink, a29k/portsw/startup/romlink,
a29k/portsw/startup/setvec.c, a29k/portsw/wrapup/.cvsignore,
a29k/portsw/wrapup/Makefile.am: Removed.
2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2003-02-03 Joel Sherrill <joel@OARcorp.com>
* shmdr/Makefile.am: Add .h files to PREINSTALL_FILES not
TMPINSTALL_FILES.
2003-01-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* shmdr/Makefile.am: install mpci.h and shm_driver.h.
Eliminate OBJS.
2003-01-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* shmdr/Makefile.am: Don't include @RTEMS_BSP@.cfg.
2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* shmdr/Makefile.am: Use .$(OBJEXT) instead of .o.
2002-08-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* include/.cvsignore: Remove.
* include/rtems/.cvsignore: Remove.
* include/rtems/score/Makefile.am: Remove.
* include/rtems/score/.cvsignore: Remove.
* configure.ac: Remove RTEMS_BSP_ALIAS.
Add RTEMS_CHECK_BSP_CACHE.
Replace $bspdir with $RTEMS_BSP_FAMILY.
* configure.ac: Remove include/Makefile, include/rtems/Makefile,
include/rtems/score/Makefile (Eliminate targopts.h).
* Makefile.am: Remove include from SUBDIRS (Eliminate targopts.h)
2002-07-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* bsp.am: Add bsplib_DATA = bsp_specs.
2002-06-25 Joel Sherrill <joel@OARcorp.com>
* Thomas Doerfler <Thomas.Doerfler@imd-systems.de> added m68k
support to the shared gdb stub glue thus adding a directory at the
top shared level.
* shared/gdbstub: New directory.
* configure.ac: Modified to reflect above.
2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* include/rtems/score/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/rtems/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shmdr/Makefile.am: Remove AUTOMAKE_OPTIONS.
2002-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* bsp.am: Add line break, remove comment.
2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* configure.in: Remove.
2001-10-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* Makefile.am: Use @subdirs@ instead of RTEMS_LIBBSP_CPU_SUBDIR.
* configure.in: AC_PREREQ(2.52), apply RTEMS_CPU_SUBDIRS, remove
2001-09-28 Joel Sherrill <joel@OARcorp.com>
* shared/bootcard.c, shared/main.c: Now call int c_rtems_main()
not main().
2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* include/rtems/score/Makefile.am: Use 'PREINSTALL_FILES ='.
* shmdr/Makefile.am: Use 'PREINSTALL_FILES ='.
2001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* Makefile.am: Use SUBDIRS = instead of SUBDIRS += to make
automake-1.5 happy.
* include/rtems/score/Makefile.am: Use CLEANFILES = to make
automake-1.5 happy.
* bsp.am: Use PREINSTALL_FILES = to make automake-1.5 happy.
2001-02-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* bsp.am: Fix automake version number in comment.
2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2000-10-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
2000-09-25 Joel Sherrill <joel@OARcorp.com>
* shmdr/shm_driver.h: Added _AM29K entry. May not be correct.
2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>
* shmdr/Makefile.am: Include compile.am
2000-08-10 Joel Sherrill <joel@OARcorp.com>
* ChangeLog: New file.
* addlq.c, cnvpkt.c, dump.c, fatal.c, getlq.c, getpkt.c, init.c,
initlq.c, intr.c, mpci.h, mpisr.c, poll.c, receive.c, retpkt.c,
send.c, setckvec.c, shm_driver.h: URL for license changed.
shmdr/Makefile.am: Reflect having moved automake.
../../configure.ac.
TMPINSTALL_FILES.
Eliminate OBJS.
that contains:
* The fix for the gen68360/network/Makefile.am
* automatically set permissions to 755 to scripts/buildall and
scripts-ada/buildall (I remembered a trick to achieve this :).
* automake support for libbsp/* and libcpu/* (Attn: This part will
finally break old-style configuration for all non-public cpus)
NOTES:
* This patch has only been tested for a random selection of BSPs (I
haven't rebuilt all toolchains yet).
* This patch is against rtem-cvs as of this morning (MET).
patch -p1 <rtems-rc-20000118-5.diff
cvs rm -f ./c/src/lib/libbsp/Makefile.in
cvs rm -f ./c/src/lib/libbsp/shmdr/Makefile.in
cvs rm -f ./c/src/lib/libcpu/Makefile.in
cvs add ./c/src/lib/libbsp/Makefile.am
cvs add ./c/src/lib/libbsp/shmdr/Makefile.am
cvs add ./c/src/lib/libcpu/Makefile.am
./bootstrap
Renamed file shmsupp/intr.c in some BSPs to shmsupp/cause_intr.c to
avoid conflict with rtems/src/intr.c (Classic API Interrupt Manager).
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
the CPU family name constants.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
to lib/include.
be resolved.
by Tony Bennett. Information table is now malloc'ed.
like signal dispatching.
+ variable length messages
+ named devices
+ debug monitor
