the CPU family name constants.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
to lib/include.
be resolved.
by Tony Bennett. Information table is now malloc'ed.
like signal dispatching.
+ variable length messages
+ named devices
+ debug monitor
