path: root/c/src/lib/libbsp/shmdr/shm_driver.h (follow)
* Rename hppa1_1 to hppa1.1 and switched to using __XXX__ macros forJoel Sherrill1998-03-241-7/+7
| | | | the CPU family name constants.
* First attempt at values for PPCJoel Sherrill1997-08-041-0/+3
* added mips64orion entries for SHM_LOCK_VALUE and SHM_UNLOCK_VALUEJoel Sherrill1996-09-081-0/+5
* Fixed so now supports more than 16 nodes. Tested for up to 24 nodesJoel Sherrill1996-04-221-1/+1
| | | | by Tony Bennett. Information table is now malloc'ed.
* updates from Tony Bennett for PA and UNIX portsJoel Sherrill1996-01-151-5/+1
* all targets compile .. tony's patches in placeJoel Sherrill1995-09-291-1/+5
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-5/+1
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-1/+1
* Numerous miscellaneous features incorporated from Tony BennettJoel Sherrill1995-08-171-0/+3
| | | | | | | | | (tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables
* minor clean up -- switched to memset for zero'ing SHMJoel Sherrill1995-08-111-32/+27
* Fully tested on all in-house targetsJoel Sherrill1995-05-241-3/+1
* Initial revisionJoel Sherrill1995-05-111-0/+542
