* shmdr/shm_driver.h: Added _AM29K entry. May not be correct.
Renamed file shmsupp/intr.c in some BSPs to shmsupp/cause_intr.c to
avoid conflict with rtems/src/intr.c (Classic API Interrupt Manager).
the CPU family name constants.
by Tony Bennett. Information table is now malloc'ed.
like signal dispatching.
+ variable length messages
+ named devices
+ debug monitor
