path: root/c/src/lib/libbsp/shmdr/mpci.h (unfollow)
2003-12-182003-12-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-58/+0
* shmdr/addlq.c, shmdr/cnvpkt.c, shmdr/dump.c, shmdr/fatal.c, shmdr/getlq.c, shmdr/getpkt.c, shmdr/init.c, shmdr/initlq.c, shmdr/intr.c, shmdr/mpci.h, shmdr/mpisr.c, shmdr/poll.c, shmdr/README, shmdr/receive.c, shmdr/retpkt.c, shmdr/send.c, shmdr/setckvec.c, shmdr/shm_driver.h: Remove (Moved to c/src/libchip/shmdr). 2003-12-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * bspstart.am: Use .$(OBJEXT) instead of .o. * Makefile.am: Remove shmdr. 2003-12-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * bsp.am: Use $(mkdir_p) instead of $(mkinstalldirs). 2003-12-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * bsp.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g. 2003-12-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g. 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. * bsp.am: Replace bsplibdir by project_libdir. Use mkdir_p instead of mkinstalldirs. Remove dirs from PRE/TMPINSTALL_FILES. 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * bsp.am: Remove project_libdir. 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: Misc. fixes. * bsp.am: Add project_libdir. 2003-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * bspstart.am: New. 2003-12-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: Merge-in shared/Makefile.am, shmdr/Makefile.am. * shared/Makefile.am: Remove. * shmdir/Makefile.am: Remove. * bsp.am: Add preinstallation dirstamp support. 2003-12-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * shmdr/Makefile.am: Remove all-local: $(ARCH). 2003-09-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * bsp.am: Reworked. 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: Reflect having moved automake/. * shmdr/Makefile.am: Reflect having moved automake/. 2003-08-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * shmdr/Makefile.am: Reflect having merged configure.ac into ../../configure.ac. 2003-08-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: Remove (Merged into ../../configure.ac). * Makefile.am: Reflect having merged configure.ac into ../../configure.ac. 2003-03-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: Remove AC_CONFIG_AUX_DIR. 2003-02-14 Joel Sherrill <joel@OARcorp.com> AMD a29k port declared obsolete. * a29k/.cvsignore, a29k/ChangeLog, a29k/Makefile.am, a29k/acinclude.m4, a29k/configure.ac, a29k/portsw/.cvsignore, a29k/portsw/ChangeLog, a29k/portsw/Makefile.am, a29k/portsw/README, a29k/portsw/bsp_specs, a29k/portsw/configure.ac, a29k/portsw/times, a29k/portsw/console/.cvsignore, a29k/portsw/console/Makefile.am, a29k/portsw/console/concntl.h, a29k/portsw/console/console.c, a29k/portsw/console/serial.c, a29k/portsw/console/serial.h, a29k/portsw/include/.cvsignore, a29k/portsw/include/Makefile.am, a29k/portsw/include/bsp.h, a29k/portsw/start/.cvsignore, a29k/portsw/start/Makefile.am, a29k/portsw/start/amd.ah, a29k/portsw/start/pswmacro.ah, a29k/portsw/start/register.S, a29k/portsw/start/register.ah, a29k/portsw/start/start.S, a29k/portsw/startup/.cvsignore, a29k/portsw/startup/Makefile.am, a29k/portsw/startup/bspclean.c, a29k/portsw/startup/bspstart.c, a29k/portsw/startup/linkcmds, a29k/portsw/startup/main.c, a29k/portsw/startup/ramlink, a29k/portsw/startup/romlink, a29k/portsw/startup/setvec.c, a29k/portsw/wrapup/.cvsignore, a29k/portsw/wrapup/Makefile.am: Removed. 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: AM_INIT_AUTOMAKE([1.7.2]). 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: AC_PREREQ(2.57). 2003-02-03 Joel Sherrill <joel@OARcorp.com> * shmdr/Makefile.am: Add .h files to PREINSTALL_FILES not TMPINSTALL_FILES. 2003-01-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * shmdr/Makefile.am: install mpci.h and shm_driver.h. Eliminate OBJS. 2003-01-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * shmdr/Makefile.am: Don't include @RTEMS_BSP@.cfg. 2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: Remove RTEMS_CHECK_BSP_CACHE. 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * shmdr/Makefile.am: Use .$(OBJEXT) instead of .o. 2002-08-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * include/Makefile.am: Remove. * include/.cvsignore: Remove. * include/rtems/Makefile.am: Remove. * include/rtems/.cvsignore: Remove. * include/rtems/score/Makefile.am: Remove. * include/rtems/score/.cvsignore: Remove. 2002-08-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: Remove RTEMS_BSP_ALIAS. Add RTEMS_CHECK_BSP_CACHE. Replace $bspdir with $RTEMS_BSP_FAMILY. 2002-08-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: Remove include/Makefile, include/rtems/Makefile, include/rtems/score/Makefile (Eliminate targopts.h). * Makefile.am: Remove include from SUBDIRS (Eliminate targopts.h) 2002-07-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * bsp.am: Add bsplib_DATA = bsp_specs. 2002-06-25 Joel Sherrill <joel@OARcorp.com> * Thomas Doerfler <Thomas.Doerfler@imd-systems.de> added m68k support to the shared gdb stub glue thus adding a directory at the top shared level. * shared/gdbstub: New directory. * configure.ac: Modified to reflect above. 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. * include/rtems/score/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/rtems/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * shmdr/Makefile.am: Remove AUTOMAKE_OPTIONS. 2002-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * bsp.am: Add line break, remove comment. 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate. 2001-10-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: Use @subdirs@ instead of RTEMS_LIBBSP_CPU_SUBDIR. * configure.in: AC_PREREQ(2.52), apply RTEMS_CPU_SUBDIRS, remove RTEMS_LIBBSP_CPU_SUBDIR. 2001-09-28 Joel Sherrill <joel@OARcorp.com> * shared/bootcard.c, shared/main.c: Now call int c_rtems_main() not main(). 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * include/rtems/score/Makefile.am: Use 'PREINSTALL_FILES ='. * shmdr/Makefile.am: Use 'PREINSTALL_FILES ='. 2001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: Use SUBDIRS = instead of SUBDIRS += to make automake-1.5 happy. * include/rtems/score/Makefile.am: Use CLEANFILES = to make automake-1.5 happy. * bsp.am: Use PREINSTALL_FILES = to make automake-1.5 happy. 2001-02-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * bsp.am: Fix automake version number in comment. 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: Use ... instead of RTEMS_TOPdir in ACLOCAL_AMFLAGS. 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: Switch to ACLOCAL_AMFLAGS = -I $(RTEMS_TOPdir)/aclocal. 2000-10-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. 2000-09-25 Joel Sherrill <joel@OARcorp.com> * shmdr/shm_driver.h: Added _AM29K entry. May not be correct. 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * shmdr/Makefile.am: Include compile.am 2000-08-10 Joel Sherrill <joel@OARcorp.com> * ChangeLog: New file.
2003-09-042003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+1
* addlq.c, cnvpkt.c, dump.c, fatal.c, getlq.c, getpkt.c, init.c, initlq.c, intr.c, mpci.h, mpisr.c, poll.c, receive.c, retpkt.c, send.c, setckvec.c, shm_driver.h: URL for license changed.
1999-11-30Renamed shm.h to shm_driver.h to avoid conflicts with POSIX shm.h.Joel Sherrill1-2/+2
Renamed file shmsupp/intr.c in some BSPs to shmsupp/cause_intr.c to avoid conflict with rtems/src/intr.c (Classic API Interrupt Manager).
1999-11-17Updated copyright notice.Joel Sherrill1-2/+1
1998-02-17updated copyright to 1998Joel Sherrill1-1/+1
1997-10-08Fixed typo in the pointer to the license terms.Joel Sherrill1-2/+2
1997-04-22headers updated to reflect new style copyright notice as partJoel Sherrill1-5/+5
1995-09-11The word "RTEMS" almost completely removed from the core.Joel Sherrill1-2/+2
Configuration Table Template file added and all tests modified to use this. All gvar.h and conftbl.h files removed from test directories. Configuration parameter maximum_devices added. Core semaphore and mutex handlers added and RTEMS API Semaphore Manager updated to reflect this. Initialization sequence changed to invoke API specific initialization routines. Initialization tasks table now owned by RTEMS Tasks Manager. Added user extension for post-switch. Utilized user extensions to implement API specific functionality like signal dispatching. Added extensions to the System Initialization Thread so that an API can register a function to be invoked while the system is being initialized. These are largely equivalent to the pre-driver and post-driver hooks. Added the Modules file oar-go32_p5, modified oar-go32, and modified the file make/custom/go32.cfg to look at an environment varable which determines what CPU model is being used. All BSPs updated to reflect named devices and clock driver's IOCTL used by the Shared Memory Driver. Also merged clock isr into main file and removed ckisr.c where possible. Updated spsize to reflect new and moved variables. Makefiles for the executive source and include files updated to show break down of files into Core, RTEMS API, and Neither. Header and inline files installed into subdirectory based on whether logically in the Core or a part of the RTEMS API.
1995-08-11minor clean up -- switched to memset for zero'ing SHMJoel Sherrill1-1/+1
