path: root/c/src/lib/libbsp/shmdr/init.c (follow)
* Renamed shm.h to shm_driver.h to avoid conflicts with POSIX shm.h.Joel Sherrill1999-11-301-1/+1
| | | | | Renamed file shmsupp/intr.c in some BSPs to shmsupp/cause_intr.c to avoid conflict with rtems/src/intr.c (Classic API Interrupt Manager).
* Fixed so now supports more than 16 nodes. Tested for up to 24 nodesJoel Sherrill1996-04-221-0/+9
| | | | by Tony Bennett. Information table is now malloc'ed.
* Modified UNIX simulator port so all references to native unixJoel Sherrill1995-09-271-0/+1
| | | | | stuff is in the executive source proper in the file cpu.c. This should help avoid conflicts between RTEMS POSIX files and UNIX files.
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-7/+5
* minor clean up -- switched to memset for zero'ing SHMJoel Sherrill1995-08-111-24/+22
* Initial revisionJoel Sherrill1995-05-111-0/+248
