init() and fini() routines.
ncurses, and zlib for RTEMS.
link even if they do not actually support Ada interrupts.
exceptions work on the pc386 BSP with i386-elf. This patch also
included changes to the i386-rtemself egcs configuration.
This problem should and likely was occurring with other BSPs. This is from
Chris' email:
I had a look in the psim bsp for the older snapshot I have and it looks
like you are using the `libbsp/shared/main.c' and this is known to work.
I have just built the powerpc tools, and compiled the bsp. I have not
added the linker command file patch so got the list of linker warnings.
It looks to me like a compiler bug. The `main' call is being inlined and
when that happens the special code to call `__eabi' is not being added
to the inlined version. I have attached a patch which places `main'
after `boot_card' and a call to main is now generated. I have not tested
it but it should work. I also include a dump of `boot_card' and `main'
showing the bug.
PROBLEMS
can/will be fixed.
Reimplemented checkRealTime() to use RTEMS internal routine.
existing TOD interface.
Modified open so it uses a local variable rather than modifying a parameter.
+ adding #include <rtems/libio.h> to fix implicit declaration warning
bspstart.c file.
component.
based on the GNU tools. This usually involved correcting the
type of bsp_start(), bsp_cleanup(), adjusting the start code to
call the right start routine (the shared boot_card()), and then
removing code from bsp_start() which was performed in the new
boot_card()/main() path.
returned an error to using a single shared copy of this file.
