Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
The VME support is only used by powerpc BSPs.
Update #3285.
The umon support is only used by the csb337 BSP.
Update #3285.
Close #3318.
* bsps/shared/cache
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3254.
Update #3248.
header file.
Update #3254.
maintain.
Update #3254.
Add BSP_VERBOSE_FATAL_EXTENSION to RTEMS_BSP_CLEANUP_OPTIONS to
optionally print the RTEMS version, the fatal source and the fatal code
in the shared bsp_fatal_extension().
Close #3248.
Due to a new rtems_panic() implementation, it is possible to replace the
PowerPC-specific BSP_panic() with rtems_panic(). Remove BSP_panic()
implementations.
Close #3245.
Use the boot time to initialize the state. Use the state, the current
CPU counter and a very simple pseudo random number generator for
getentropy(). At least, this enables to pass the test "GETENTROPY 1" on
ERC32.
Update #3239.
Update #3239.
Update #3090.
Pass all interrupt cells to bsp_fdt_map_intr() since some platforms use
an array to describe an interrupt.
Update #3090.
Remove old ISR parameter since is not used by the clock driver shell.
Make an implementation optional.
Update #3139.
Update #3132.
The BSP_output_char should output a char and not mingle with high level
processing, e.g. '\n' to '\r\n' translation. Move this translation to
rtems_putc(). Remove it from all the BSP_output_char implementations.
Close #3122.
Update #2133.
Update #3082.
Update #3082.
Update #3090.
Update #3090.
Make Clock_driver_support_shutdown_hardware() optional. This avoids
the atexit() support on memory constrained targets.
Update #3071.
Update #3071.
Close #3071.
Update #3071.
Update #3071.
This mechanism can be used to safely move the interrupt server from one
scheduler instance to another for example.
Update #3071.
This allows load balancing of interrupt processing in SMP
configurations.
Update #3071.
Update #3059.
Implement the Processor_mask via <sys/bitset.h>. Provide
_Processor_mask_To_uint32_t() to enable its use in device specific
routines, e.g. interrupt affinity register in an interrupt controller.
Update #3059.
Change bsp_interrupt_vector_enable() and bsp_interrupt_vector_disable()
to not return a status code. Add bsp_interrupt_assert() and use it to
validate the vector number in the vector enable/disable implementations.
Closes #3014.
