* | Switch to using a shared main() for all of the embedded BSPs | Joel Sherrill | 1998-03-21 | 2 | -0/+79 |
| | | | | | | | | based on the GNU tools. This usually involved correcting the type of bsp_start(), bsp_cleanup(), adjusting the start code to call the right start routine (the shared boot_card()), and then removing code from bsp_start() which was performed in the new boot_card()/main() path. | ||||
* | Fixed typo. | Joel Sherrill | 1998-03-20 | 1 | -1/+1 |
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 1 | -1/+1 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 1 | -2/+2 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 1 | -5/+5 |
* | Switched all bsps which had an implementation of sbrk.c which only | Joel Sherrill | 1997-04-15 | 1 | -0/+32 |
returned an error to using a single shared copy of this file. |
