to address m68k-rtemself for the MVME167.
Here is the rtems patch I promissed you a long time ago to enable ELF
with m68k. The target name I selected is m68k-rtemself. It preserves the
m68k-rtems COFF target, and is parterned after the other ELF/COFF dual
targets.
The mvme167.cfg file causes the -qelf flag to be used during compilation
if the name of the compiler contains rtemself. This flag is used in the
bsp_specs file to select the elflinkcmds file rather than the linkcmds
file. The former is for ELF, the latter for COFF.
Some patches are required to the mc68040 FPSP code. Some of the
assembler files contain instructions that were rejected by the
m68k-rtemself-as assembler. This is a minor bug in the m68k ELF
assembler, I think.
init() and fini() routines.
ncurses, and zlib for RTEMS.
link even if they do not actually support Ada interrupts.
exceptions work on the pc386 BSP with i386-elf. This patch also
included changes to the i386-rtemself egcs configuration.
This problem should and likely was occurring with other BSPs. This is from
Chris' email:
I had a look in the psim bsp for the older snapshot I have and it looks
like you are using the `libbsp/shared/main.c' and this is known to work.
I have just built the powerpc tools, and compiled the bsp. I have not
added the linker command file patch so got the list of linker warnings.
It looks to me like a compiler bug. The `main' call is being inlined and
when that happens the special code to call `__eabi' is not being added
to the inlined version. I have attached a patch which places `main'
after `boot_card' and a call to main is now generated. I have not tested
it but it should work. I also include a dump of `boot_card' and `main'
showing the bug.
PROBLEMS
can/will be fixed.
Reimplemented checkRealTime() to use RTEMS internal routine.
existing TOD interface.
Modified open so it uses a local variable rather than modifying a parameter.
+ adding #include <rtems/libio.h> to fix implicit declaration warning
bspstart.c file.
component.
based on the GNU tools. This usually involved correcting the
type of bsp_start(), bsp_cleanup(), adjusting the start code to
call the right start routine (the shared boot_card()), and then
removing code from bsp_start() which was performed in the new
boot_card()/main() path.
returned an error to using a single shared copy of this file.
