* | 2010-12-30 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-12-30 | 4 | -1/+76 |
| | | | | | | * shared/bspgetworkarea.c: Include <bsp/u-boot.h> if necessary. * shared/include/u-boot.h, shared/src/bsp-uboot-board-info.c: New files. | ||||
* | 2010-10-14 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-10-14 | 2 | -80/+84 |
| | | | | * include/utility.h: Renamed macros. | ||||
* | 2010-09-08 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-09-08 | 2 | -5/+118 |
| | | | | * include/utility.h: More macros. Changed casts. | ||||
* | 2010-08-15 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-08-15 | 2 | -1/+6 |
| | | | | * src/uart-output-char.c: Add BSP_poll_char. | ||||
* | Typo. | Sebastian Huber | 2010-07-27 | 1 | -1/+1 |
* | 2010-07-27 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-07-27 | 2 | -7/+11 |
| | | | | * umon/tfsDriver.c: Update for LibIO API changes. | ||||
* | 2010-06-30 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-06-30 | 2 | -3/+6 |
| | | | | * umon/tfsDriver.c: Remove extra brace. | ||||
* | 2010-06-30 Jennifer Averett <Jennifer.Averett@OARcorp.com> | Jennifer Averett | 2010-06-30 | 2 | -1/+6 |
| | | | | | * umon/tfsDriver.c: Corrected filesystem mknod entry to call the default handler. | ||||
* | 2010-06-29 Jennifer.Averett <Jennifer.Averett@OARcorp.com> | Jennifer Averett | 2010-06-29 | 2 | -30/+38 |
| | | | | | * umon/tfsDriver.c: Changed NULL methods in filesystem tables to be default methods. | ||||
* | 2010-05-31 Chris Johns <chrisj@rtems.org> | Chris Johns | 2010-05-31 | 1 | -11/+13 |
| | | | | * shared/umon/tfsDriver.c: Updated to the new mount API. | ||||
* | 2010-05-28 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-05-28 | 2 | -1/+6 |
| | | | | | * umon/tfsDriver.c: Use size_t instead of int for pathnamelen. | ||||
* | Whitespace removal. | Sebastian Huber | 2010-05-21 | 1 | -2/+2 |
* | 2010-05-21 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-05-21 | 2 | -8/+13 |
| | | | | | * include/utility.h: Macros use now first and last bit values instead of shift and length parameters. | ||||
* | 2010-05-20 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-05-20 | 2 | -44/+24 |
| | | | | * include/utility.h: Removed superfluous macros. | ||||
* | 2010-05-20 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-05-20 | 3 | -0/+105 |
| | | | | * include/uart-output-char.h, src/uart-output-char.c: New files. | ||||
* | 2010-04-30 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-04-30 | 5 | -92/+87 |
| | | | | | | | | | | * include/irq-config.h: Removed file. * include/irq.h: New file (renamed from 'include/irq-config.h'). * include/irq-generic.h, src/irq-info.c: Include <bsp/irq.h> instead of <bsp/irq-config.h>. * src/irq-server.c: Use events instead of semaphore. Added error counter for multiple chain appends. Added error counter to detect erroneous interrupt events. | ||||
* | 2010-04-30 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-04-30 | 2 | -3/+7 |
| | | | | * include/bootcard.h: Documentation. | ||||
* | 2010-04-28 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-04-28 | 2 | -1/+4 |
| | | | | * gdbstub/rtems-stub-glue.c: Remove warnings. | ||||
* | 2010-04-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2010-04-14 | 1 | -4/+4 |
| | | | | | * shared/umon/umoncons.c: Reflect changes to rtems_termios_callbacks->write. | ||||
* | unify irq data types and code, merge s3c2400/s3c2410 support | Thomas Doerfler | 2010-04-09 | 2 | -2/+6 |
* | fix warning | Thomas Doerfler | 2010-03-25 | 2 | -1/+5 |
* | 2009-12-10 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-12-10 | 1 | -2/+2 |
| | | | | | * shared/console-polled.c: Reflect changes to rtems_termios_callbacks->write. | ||||
* | 2009-12-04 Fernando Nicodemos <fgnicodemos@terra.com.br> | Joel Sherrill | 2009-12-04 | 3 | -16/+41 |
| | | | | * umon/README, umon/tfs.h: Missing parts of previous commit. | ||||
* | 2009-11-30 Fernando Nicodemos <fgnicodemos@terra.com.br> | Joel Sherrill | 2009-11-30 | 8 | -89/+149 |
| | | | | | | * umon/cli.h, umon/monlib.c, umon/monlib.h, umon/tfs.h, umon/tfsDriver.c, umon/umon.h, umon/umonrtemsglue.c: Update to match development version. | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 7 | -10/+10 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 16 | -225/+225 |
* | 2009-11-23 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-11-23 | 2 | -52/+32 |
| | | | | * clockdrv_shell.h: Clean up. | ||||
* | 2009-11-03 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-11-03 | 1 | -0/+1 |
| | | | | | * shared/umon/tfsDriver.c (rtems_tfs_eval_path): Add missing parameter. | ||||
* | add missing change | Thomas Doerfler | 2009-10-21 | 2 | -4/+16 |
* | interrupt handler type change | Thomas Doerfler | 2009-10-21 | 4 | -90/+20 |
* | 2009-10-09 Sebastian Huber <sebastian.huber@embedded-brains.de> | Joel Sherrill | 2009-10-12 | 2 | -54/+35 |
| | | | | * bootcard: Update for heap API changes. | ||||
* | 2009-10-09 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2009-10-09 | 1 | -1/+8 |
| | | | | | | | * shared/vmeUniverse/vmeUniverse.c: print message and let vmeUniverseIntLoopbackTst() fail if odd-numbered vector is used (cannot program the chip to reply with such a vector). | ||||
* | 2009-09-08 Sebastian Huber <sebastian.huber@embedded-brains.de> | Joel Sherrill | 2009-09-08 | 13 | -606/+1079 |
| | | | | | | | | | * include/irq-config.h, include/irq-generic.h, include/irq-info.h, src/irq-generic.c, src/irq-info.c, src/irq-legacy.c, src/irq-shell.c: Format, cleanup and documentation. * src/irq-server.c: New file. * include/bootcard.h, include/stackalloc.h, src/stackalloc.c, bsplibc.c: Update for heap API changes. Documentation. | ||||
* | 2009-08-28 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-08-28 | 5 | -78/+55 |
| | | | | | * bootcard.c, bsplibc.c, clockdrv_shell.h, console-polled.c: Fix formatting. | ||||
* | 2009-08-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-08-12 | 2 | -115/+127 |
| | | | | | * src/irq-legacy.c: Spacing, tabs, and proper format for license notice. | ||||
* | 2009-08-10 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-08-10 | 2 | -17/+30 |
| | | | | | * console.c: Fix tabs and allow the BSP to override the default baud rate. | ||||
* | 2009-07-22 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-07-22 | 2 | -1/+6 |
| | | | | | * src/irq-generic.c: Priority inheritance on simple binary semaphores makes no sense and has recently been added as an error condition. | ||||
* | adding lpc24xx BSP parts | Thomas Doerfler | 2009-07-17 | 2 | -0/+116 |
* | ARM bsp maintenance | Thomas Doerfler | 2009-07-17 | 1 | -0/+4 |
* | 2009-07-06 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-07-06 | 2 | -4/+12 |
| | | | | * setvec.c: Add CVS Id. | ||||
* | 2009-06-18 Fernando Nicodemos <fgnicodemos@terra.com.br> | Joel Sherrill | 2009-06-18 | 3 | -1/+141 |
| | | | | | | | * umon/umonrtemsglue.c: Add console device that uses MicroMonitor to do actual input and output. This driver should work on any board that uses MicroMonitor. * umon/umoncons.c: New file. | ||||
* | 2009-06-17 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 2009-06-17 | 3 | -2/+7 |
| | | | | | * vmeUniverse/vmeUniverse.c, vmeUniverse/vmeTsi148.c: include <rtems/pci.h> instead of <bsp/pci.h>. | ||||
* | 2009-06-15 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-06-15 | 2 | -0/+12 |
| | | | | | * umon/umonrtemsglue.c: Add flag to ensure that it umon connection is initialized twice, it is safe. | ||||
* | 2009-06-15 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-06-15 | 3 | -24/+64 |
| | | | | | | * umon/monlib.h: Add umon.h to be installed as <rtems/umon.h> so umon .h files are modified as little as possible. * umon/umon.h: New file. | ||||
* | 2009-06-12 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-06-12 | 8 | -0/+2504 |
| | | | | | * umon/README, umon/cli.h, umon/monlib.c, umon/monlib.h, umon/tfs.h, umon/tfsDriver.c, umon/umonrtemsglue.c: New files. | ||||
* | 2009-05-27 Sebastian Huber <sebastian.huber@embedded-brains.de> | Joel Sherrill | 2009-05-27 | 3 | -8/+110 |
| | | | | * tod.h, tod.c: Update for new RTC driver interface. | ||||
* | 2009-05-18 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-05-18 | 2 | -1/+5 |
| | | | | * bsppost.c: Fix typo. | ||||
* | 2009-05-15 Sebastian Huber <sebastian.huber@embedded-brains.de> | Joel Sherrill | 2009-05-15 | 3 | -8/+12 |
| | | | | * include/irq-generic.h, src/irq-generic.c: Documentation. | ||||
* | 2009-05-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-05-08 | 4 | -17/+24 |
| | | | | | | * bootcard.c, bspgetworkarea.c, include/bootcard.h: Switch from ssize_t to uintptr_t for bsp_get_work_area() since the work area is larger than a single allocatable object. | ||||
* | 2009-05-06 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-05-06 | 2 | -0/+7 |
| | | | | * bspinit.c: Fix warning by adding include file. |
